#2045: r.to.vect: use less memory
Reporter: mlennert | Owner: grass-dev@…
Priority: normal | Milestone: 7.0.5
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.to.vect
Comment (by mmetz):
Replying to [comment:10 mlennert]:
> A colleague who was trying to vectorize +/- 13 mio segments (output of
i.segment) just ran into the same problem of memory saturation during the
topology creation phase.
As a workaround, you could use `r.to.vect -b` and then build topology
separately with v.build.
> The tiling approach is interesting, we will look into that,
See also the GRASS addon r.to.vect.tiled [0]
> but it would be nice if a possibility was found to make the whole
r.to.vect process more efficient. I have no idea, how, though...
The module already writes out a boundary as soon as it has been completed
and attempts to free memory used to track this boundary. I suspect more
serious memory leaks in r.to.vect during the extraction phase. Even though
the module tries to free all memory used during extraction, it seems that
some allocated memory is no longer accessible. I have an idea where to
look for the memory leak
([https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.to.vect/areas.c#L157
update_list()]), but it will not be a quick fix.
[0] https://grass.osgeo.org/grass70/manuals/addons/r.to.vect.tiled.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/2045#comment:11>
