#2045: r.to.vect: use less memory
Reporter: mlennert | Owner: grass-dev@…
Priority: normal | Milestone: 7.0.5
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.to.vect
Comment (by mlennert):
Replying to [comment:12 mmetz]:
> Replying to [comment:11 mmetz]:
> > The module already writes out a boundary as soon as it has been
completed and attempts to free memory used to track this boundary.
> The attempt was unsuccessful, also for lines, fixed in r68716.
That helps a lot !
Without (i.e. grass70) my machine became unusable for a while and then the
module execution stopped after a bit more than 5 minutes because of too
little memory. With the fix (grass73) it went all the way to 100% of
writing areas (17 minutes on my machine), but then I got an error
"Category index is not up to date".
I used r.to.vect -vb as I want to preserve category values of the raster
file.
However, my colleague's problem was not in the vectorization stage, but in
the topology building stage. I'm currently testing with -vt and
VECTOR_LOW_MEM=1. It's been running for about 1 h. I'll see tomorrow what
the result is...
I'll also try with -vb, followed by v.build.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2045#comment:13>
