#2045: r.to.vect: use less memory
Reporter: mlennert | Owner: grass-dev@…
Priority: normal | Milestone: 7.0.5
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.to.vect
Comment (by mmetz):
Replying to [comment:13 mlennert]:
> Without (i.e. grass70) my machine became unusable for a while and then
the module execution stopped after a bit more than 5 minutes because of
too little memory. With the fix (grass73) it went all the way to 100% of
writing areas (17 minutes on my machine), but then I got an error
"Category index is not up to date".
The -v and -b flags are mutually exclusive. The -v flag is disabled for
certain input/flag combinations, but this test was missing. Added in trunk
r68720.
> However, my colleague's problem was not in the vectorization stage, but
in the topology building stage. I'm currently testing with -vt and
VECTOR_LOW_MEM=1. It's been running for about 1 h. I'll see tomorrow what
the result is...
The topology building stage might need a lot of memory. If a lot of memory
is still in use because of a memory leak in the extraction stage, the
topology building stage is more likely to fail because of an out-of-memory
error. There is no guarantee that topology building will succeed, but the
chances for success are higher now that the (hopefully last) memory leak
in the extraction stage has been fixed. If topology building still fails
with an out-of-memory error, try again with the environment variable
GRASS_VECTOR_LOWMEM set.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2045#comment:14>
