[GRASS-dev] [GRASS GIS] #2045: r.to.vect: use less memory
  Reporter: mlennert | Owner: grass-dev@…
      Type: enhancement | Status: closed
  Priority: normal | Milestone: 7.0.5
Component: Raster | Version: svn-trunk
Resolution: fixed | Keywords: r.to.vect
Comment (by mmetz):
Replying to [comment:25 mlennert]:
> Replying to [comment:20 mmetz]:
> > Replying to [comment:19 mlennert]:
> > > Data and info provided via private mail.
> > I have received the data, thanks!
> > > Previous posters have also reported that setting GRASS_VECTOR_LOWMEM
didn't make much of a difference, so maybe the problem is there ?
> > I don't think so. Without GRASS_VECTOR_LOWMEM, v.build needs about 26
GB of RAM. With GRASS_VECTOR_LOWMEM, v.build needs about 11 GB of RAM
> A question that came up in a discussion with colleagues: could this
memory need be determined before building topology and possibly check for
enough available memory / warn the user ?
Unfortunately not because the number of features is unknown when topology
building starts. What could be done is counting primitives without
building topology, then estimate memory requirements just for these
primitives. The number of areas can not be estimated.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2045#comment:26&gt;
