#205: warnings and errors when trying to print the display
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: Linux
Cpu: x86-64 |
1. add a map
2. display it
3. "Print display" - as the window pops up, following debug info is
printed to terminal:
(python:23706): GnomePrint-WARNING **: Could not create filter from
description 'GnomePrintFilterSelect': filter 'GnomePrintFilterSelect' is
unknown
(python:23706): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(python:23706): GLib-GObject-CRITICAL **: g_signal_connect_data: assertion
`G_TYPE_CHECK_INSTANCE (instance)' failed
description 'GnomePrintFilterClip [ GnomePrintFilterMultipage ]': filter
'GnomePrintFilterClip' is unknown
(python:23706): GLib-GObject-CRITICAL **: g_object_unref: assertion
`G_IS_OBJECT (object)' failed
(python:23706): libgnomeprintui-CRITICAL **:
gnome_print_layout_selector_load_filter: assertion `GNOME_IS_PRINT_FILTER
(f)' failed
(python:23706): GLib-GObject-CRITICAL **: g_object_set: assertion
gnome_paper_selector_load_paper_size: assertion `GNOME_IS_PAPER_SELECTOR
(ps)' failed
(python:23706): GnomePrint-CRITICAL **: gnome_print_filter_reset:
assertion `GNOME_IS_PRINT_FILTER (f)' failed
(python:23706): GnomePrint-CRITICAL **: gnome_print_filter_flush:
(ps)' failed
** (python:23706): WARNING **: could not set the value of
Settings.Document.Filter, node not found
Ticket URL: <http://trac.osgeo.org/grass/ticket/205>
