#2051: r.to.vect: add option to not create attribute table if -v flag is used
Reporter: mlennert | Owner: grass-dev@…
Priority: minor | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: r.to.vect attribute table | Platform: Unspecified
Cpu: Unspecified |
The -v flag of r.to.vect allows to use the pixel values of a CELL raster
as category values of the created vector features. In that case and in
certain circumstances it might not be necessary to create a database table
for the output vector. It would thus be nice if r.to.vect had an option
that would allow not to create an attribute table if the -v flag is used.
Cpu: Unspecified |
Comment(by mmetz):
Replying to [ticket:2051 mlennert]:
Try r57333.
The change is slightly different than requested: the creation of an
attribute table can also be suppressed if the -v flag is not used, in
which case a warning is printed out that raster values will be lost.
Sometimes it might be useful to just have e.g. areas or lines with a
unique category and the raster values are no longer needed.
Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:1 mmetz]:
raster as category values of the created vector features. In that case and
in certain circumstances it might not be necessary to create a database
table for the output vector. It would thus be nice if r.to.vect had an
option that would allow not to create an attribute table if the -v flag is
used.
> Try r57333.
Thanks ! I agree with your version of the change.
Won't have the time to test, though, as I'm leaving on vacation in a few
hours...
