[GRASS-dev] [GRASS GIS] #2052: r.in.gdal should not by default call first three bands red, green, blue
Reporter: mlennert | Owner: grass-dev@…
Component: Default | Version: unspecified
Keywords: r.in.gdal rgb | Platform: Unspecified
      Cpu: Unspecified |
Working with multispectral satellite data in tiff where bands are not just
red, green, blue, but, for example (for Worldview 2):
1:Coastal
2:Blue
3:Green
4:Yellow
5:Red
6:Red Edge
7:NIR1
8:NIR2
it is a bit annoying that r.in.gdal automatically calls the first three
bands .red, .green and .blue. Even in satellite imagery which has only
three bands, this does not necessarily mean that they are rgb. Calling
them .red, .green and .blue can leave to confusion for the inexperienced
user.
I would suggest to remove that functionality and leave it up to the user
to decide what the bands represent.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2052&gt;
      Cpu: Unspecified |
Comment(by nikosa):
I can only agree that it might confuse people (working these days also
with IKONOS, QB and WV2 data).
Also, somewhat related, it seems that in the past, QuickBird delivered
data in a different order? See some reference/instructions in the wiki
[http://grasswiki.osgeo.org/wiki/QuickBird#Cleanup].
I will alter the wiki as this is no (longer?) valid -- QuickBird MS bands
are in the "expected" order for me (that is B, G, R and NIR) -- and keep
it as an extra note in case if...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2052#comment:1&gt;
Component: Raster | Version: svn-trunk
      Cpu: Unspecified |
Changes (by hamish):
  * version: unspecified => svn-trunk
  * component: Default => Raster
Comment:
I'm not 100% sure, but ISTR that it was libgdal doing that, r.in.gdal was
just passing the band name along untouched. --> gdal band name detection
bug?
It would be bad if the (e.g.) ".blue" band was being named ".red"!
Hamish
ps- trac's parser logic wants keywords separated by commas
Ticket URL: <https://trac.osgeo.org/grass/ticket/2052#comment:2&gt;
Keywords: r.in.gdal, rgb | Platform: Unspecified
      Cpu: Unspecified |
  * keywords: r.in.gdal rgb => r.in.gdal, rgb
Ticket URL: <https://trac.osgeo.org/grass/ticket/2052#comment:3&gt;
      Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:2 hamish]:
was just passing the band name along untouched. --> gdal band name
detection bug?
detection bug?
Yes and no: GDAL does return a ColorInterp info which is "wrong", but this
is apparently due to the original data:
[https://trac.osgeo.org/gdal/ticket/5177\]
The problem in r.in.gdal is here:
[https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.in.gdal/main.c#L525].
Noted. Thanks for the hint !
Ticket URL: <https://trac.osgeo.org/grass/ticket/2052#comment:4&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:4 mlennert]:
detection bug?
> Yes and no: GDAL does return a !ColorInterp info which is "wrong", but
this is apparently due to the original data:
That means the -k flag should be removed and the band number always used
as suffix, or optionally the meaning of the -k flag should be reverted
such that color names are appended only on request?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2052#comment:5&gt;
      Cpu: Unspecified |
Replying to [comment:5 mmetz]:
r.in.gdal was just passing the band name along untouched. --> gdal band
name detection bug?
Duh. I have to admit that I completely overlooked this flag. So the
question is: what is less confusion for newcomers: have rgb extensions
sometimes not be correct, or always only have numbers ?
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2052#comment:6&gt;
      Cpu: Unspecified |
Comment(by hamish):
Replying to [comment:6 mlennert]:
> So the question is: what is less confusion for newcomers: have rgb
> extensions sometimes not be correct, or always only have numbers ?
I'd go with option (c): complain to the data providers until they correct
their files. Better result for everyone in the long run.
rouault:
> > From the above output, the file must have TIFFTAG_PHOTOMETRIC
(wrongly) set to
> > PHOTOMETRIC_RGB. So the problem is more on the producer of the file.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2052#comment:7&gt;
      Cpu: Unspecified |
Comment(by nikosa):
This is still unresolved. I did my part for option (c) a year ago,
launching an open and direct discussion with a Digital Globe's
representative salesman n Europe. No reply in the end.
I still feel that the default import scheme shouldn't take red, green and
blue for granted.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2052#comment:8&gt;
