[GRASS-dev] [GRASS GIS] #206: SQL builder prints the name of the vector map to the terminal
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: Linux
      Cpu: x86-64 |
1. add a vector map
2. right click it on the list > "Show attribute data"
3. check "Advanced"
4. press "SQL Builder"
The vector map's name is printed to the terminal which should not take
place. Also, as you click around errors "(python:5988): Gtk-WARNING **:
gtk_widget_size_allocate(): attempt to allocate widget with width -5 and
height 15" are printed too.
Ticket URL: <http://trac.osgeo.org/grass/ticket/206&gt;
  Priority: minor | Milestone: 6.4.0
Resolution: | Keywords:
  Platform: Linux | Cpu: x86-64
Changes (by martinl):
  * priority: major => minor
Comment:
Just note here that SQL Builder is plan to be rewritten, see
http://grass.osgeo.org/wiki/WxPython-based_GUI_for_GRASS#Roadmap_4.
Ticket URL: <http://trac.osgeo.org/grass/ticket/206#comment:1&gt;
  Reporter: msieczka | Owner: martinl
      Type: defect | Status: assigned
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Comment:
I removed print statements (r31959, r31960). Anyway Gtk-WARNINGs need to
be fix.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/206#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  * status: assigned => closed
  * resolution: => fixed
Comment:
Closed, Gtk-WARNINGs reported #207.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/206#comment:3&gt;
