[GRASS-dev] [GRASS GIS] #2065: grass70 not detecting latest source build of libLAS (1.7.0)
Reporter: rashadkm | Owner: grass-dev@…
     Type: defect | Status: new
Component: Compiling | Version: svn-trunk
Keywords: liblas | Platform: Linux
      Cpu: All |
when compiling grass70 from source using the config below with libLAS
enabled. I am getting an error
''./configure --with-freetype-includes=/usr/include/freetype2 --with-
postgres-includes=/usr/pgsql-9.2/include/ --with-postgres --with-readline
--with-nls --with-blas --with-lapack --with-wxwidgets --with-sqlite
--with-geos --with-mysql-includes=/usr/include/mysql --with-mysql --with-
netcdf --with-liblas=/home/rashad/local/bin/liblas-config --with-
freetype''
'''Config output:'''
checking host system type... x86_64-unknown-linux-gnu
checking for gcc... gcc
checking whether the C compiler (gcc -Wall -g ) works... yes
checking whether the C compiler (gcc -Wall -g ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for Cygwin environment... no
checking for mingw32 environment... no
checking for executable suffix... no
checking for full floating-point support... yes
checking for pwd... /usr/bin/pwd
checking for source directory... /home/rashad/repos/grass/grass70
checking for build directory... /home/rashad/repos/grass/grass70
checking for svnversion... /usr/bin/svnversion
checking for MacOSX App... no
checking for MacOSX architectures... no
checking for MacOSX SDK... no
checking how to build libraries... shared
checking for additional include dirs...
checking for additional library dirs...
checking for a BSD compatible install... /usr/bin/install -c
checking for flex... flex
checking for yywrap in -lfl... no
checking for bison... bison -y
checking for ranlib... ranlib
checking for ar... ar
checking for env... env
checking for perl... /usr/bin/perl
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for limits.h... yes
checking for termio.h... yes
checking for termios.h... yes
checking for unistd.h... yes
checking for values.h... yes
checking for f2c.h... no
checking for g2c.h... no
checking for sys/ioctl.h... yes
checking for sys/mtio.h... yes
checking for sys/resource.h... yes
checking for sys/time.h... yes
checking for sys/timeb.h... yes
checking for sys/types.h... yes
checking for sys/utsname.h... yes
checking for libintl.h... yes
checking for iconv.h... yes
checking for langinfo.h... yes
checking whether time.h and sys/time.h may both be included... yes
checking for off_t... yes
checking for uid_t in sys/types.h... yes
checking return type of signal handlers... void
checking for ftime... yes
checking for gethostname... yes
checking for gettimeofday... yes
checking for lseek... yes
checking for nice... yes
checking for time... yes
checking for uname... yes
checking for seteuid... yes
checking for setpriority... yes
checking for setreuid... yes
checking for setruid... no
checking for drand48... yes
checking for putenv... yes
checking for setenv... yes
checking for nanosleep... yes
checking whether setpgrp takes no argument... yes
checking for long long int... yes
checking for W11... no
checking for X... libraries , headers
checking for dnet_ntoa in -ldnet... no
checking for dnet_ntoa in -ldnet_stub... no
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking for library containing cuserid... none required
checking for asprintf... yes
checking for atan... no
checking for atan in -lm... yes
checking for dlsym... no
checking for dlsym in -ldl... yes
checking for iconv... yes
checking for socket... yes
checking for location of zlib includes...
checking for zlib.h... yes
checking for location of zlib library...
checking for deflate in -lz... yes
checking for location of External PROJ.4 includes...
checking for proj_api.h... yes
checking External PROJ.4 version... 480
checking for location of External PROJ.4 library...
checking for pj_get_def in -lproj... yes
checking for location of External PROJ.4 data files...
configure: warning: *** External PROJ.4 directory not specified; default
will be used
checking for /usr/local/share/proj/epsg... no
configure: warning: *** Unable to locate PROJ data files.
checking for nad2bin... /usr/bin/nad2bin
checking whether to use regex... yes
checking for location of regex includes...
checking for regex.h... yes
checking for location of regex library...
checking for regcomp... yes
checking whether to use Readline... yes
checking for location of Readline includes...
checking for readline/readline.h... yes
checking for readline/history.h... yes
checking for location of Readline library...
checking for readline in -lreadline... yes
checking for add_history in -lhistory... yes
checking whether to use GDAL... yes
checking for gdal-config... /usr/bin/gdal-config
checking whether to use libLAS... yes
checking for liblas-config... /home/rashad/local/bin/liblas-config
configure: error: *** Unable to locate libLAS library.
I had downloaded libLAS from [1] and installed in ~/local and liblas-
config exists here ~/local/bin/liblas-config. but grass configure always
fails. Below is the output from config.log
configure:6088: checking for gdal-config
configure:6150: gcc -o conftest -Wall -g -I/usr/include/gdal -Wl
,--export-dynamic conftest.c -L/usr/lib64 -lgdal 1>&5
configure: In function 'main':
configure:6146:9: warning: ignoring return value of 'GDALOpen', declared
with attribute warn_unused_result [-Wunused-result]
configure:6198: checking whether to use libLAS
configure:6215: checking for liblas-config
configure:6270: gcc -o conftest -Wall -g -pedantic -ansi -Wall -Wpointer-
arith -Wcast-align -Wcast-qual -Wfloat-equal -Wredundant-decls -Wno-long-
long -std=c++98 -Wl,--export-dynamic conftest.c
-L/home/rashad/local/lib -llas -llas_c -L/usr/lib64 /usr/lib64
/libboost_program_options-mt.so /usr/lib64/libboost_thread-mt.so 1>&5
cc1: warning: command line option '-std=c++98' is valid for C++/ObjC++ but
not for C [enabled by default]
configure:6264:32: fatal error: liblas/capi/liblas.h: No such file or
directory
compilation terminated.
configure: failed program was:
#line 6263 "configure"
#include "confdefs.h"
#include <liblas/capi/liblas.h>
int main() {
LASReader_Create("foo");
; return 0; }
configure:6285: gcc -o conftest -Wall -g -pedantic -ansi -Wall -Wpointer-
configure:6279:32: fatal error: liblas/capi/liblas.h: No such file or
directory
#line 6278 "configure"
int main() {
; return 0; }
liblas-config --includes gives this
~/local/include
Adding the '''LIBLAS_INC''' to '''CFLAGS''' solved this
please find attached patch. I modified the configure script. But I think
there is a better way to do this
[1] http://download.osgeo.org/liblas/libLAS-1.7.0.tar.gz
Ticket URL: <http://trac.osgeo.org/grass/ticket/2065&gt;
      Cpu: All |
Comment(by glynn):
Replying to [ticket:2065 rashadkm]:
Try r57541.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2065#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: liblas
  Platform: Linux | Cpu: All
Changes (by neteler):
  * status: new => closed
  * resolution: => fixed
Comment:
Solved, closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2065#comment:2&gt;
Comment(by hamish):
currently I'm getting this error with trunk on Debian Wheezy,
./configure ... --with-liblas
checking for liblas-config... /usr/bin/liblas-config
$ /usr/bin/liblas-config --cflags
-Wall -Wno-long-long -pedantic -g -O2 -fstack-protector --param=ssp-
buffer-size=4 -Wformat -Wformat-security -Werror=format-security -Wall -O3
-DNDEBUG
$ /usr/bin/liblas-config --includes
-I/usr/include/geotiff -I/usr/include/gdal
config.log:
configure:6272: gcc -o conftest -ggdb -march=amdfam10 -Wall -Werror-
implicit-function-declaration -fno-common
  -Wextra -Wunused -Wall -Wno-long-long -pedantic -g -O2 -fstack-protector
--param=ssp-buffer-size=4 -Wformat
  -Wformat-security -Werror=format-security -Wall -O3 -DNDEBUG
-I/usr/include/geotiff -I/usr/include/gdal -W
l,--export-dynamic conftest.c -L/usr/lib -lgeotiff -L/usr/lib -lgdal 1>&5
/tmp/ccrOhqrK.o: In function `main':
/home/hamish/src/grass/svn/trunk/configure:6268: undefined reference to
`LASReader_Create'
collect2: error: ld returned 1 exit status
#line 6265 "configure"
int main() {
; return 0; }
configure:6287: gcc -o conftest -ggdb -march=amdfam10 -Wall -Werror-
/tmp/cc85WCPw.o: In function `main':
/home/hamish/src/grass/svn/trunk/configure:6283: undefined reference to
`LASReader_Create'
#line 6280 "configure"
int main() {
; return 0; }
$ grep -r LASReader_Create /usr/include/liblas *
/usr/include/liblas/capi/liblas.h:LAS_DLL LASReaderH
LASReader_Create(const char * filename);
$ apt-cache policy liblas-dev
liblas-dev:
   Installed: 1.2.1-5+b1
any ideas?
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2065#comment:3&gt;
Comment(by lucadelu):
Replying to [comment:3 hamish]:
> liblas-dev:
> any ideas?
I think liblas version is very old, try with newer one.
> thanks,
> Hamish
Best
Luca
Ticket URL: <https://trac.osgeo.org/grass/ticket/2065#comment:4&gt;
Comment(by hamish):
Replying to [comment:4 lucadelu]:
It's the stock version for Debian/Stable (Wheezy) and Ubuntu 12.04 LTS &
so should reasonably be supported. ISTR Howard saying there was an old
version which would do well to be flushed out of the system. Was it 1.2 or
earlier?
If there is a fundamental reason to make 1.7 or newer required, then
REQUIREMENTS.html should note that. But I'm not sure there is & wrt this
ticket the fn in question does exist in the 1.2 header.
regards,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/2065#comment:5&gt;
  Priority: normal | Milestone: 7.1.0
Changes (by epifanio):
* cc: epifanio (added)
  * milestone: 7.0.0 => 7.1.0
Comment:
Exact same problem building grass 7.1-svn on debian sid (liblas 1.8)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2065#comment:6&gt;
       CPU: All | Platform: Linux
Comment (by morenocomelli):
Same problem building grass 7.0.0 on CentOS 7.
liblas 1.8 is installed via yum
Ticket URL: <http://trac.osgeo.org/grass/ticket/2065#comment:7&gt;
Comment (by neteler):
Replying to [comment:7 morenocomelli]:
Please check "config.log" for the true error. Maybe liblas-devel is not
installed?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2065#comment:8&gt;
