[GRASS-dev] [GRASS GIS] #2068: d.out.file fails
Reporter: laurimyllyvirta | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Default | Version: 6.4.2
Keywords: | Platform: MSWindows 7
      Cpu: x86-32 |
Thank you so much for an amazing piece of free software.
When trying to save the display as an image in wxGUI, I get the error
below. No image file gets created. I have tried to vary the contents of
the display, the dimensions of the image etc. but the result is
consistently the same.
   File "C:\Program Files\GRASS
6.4.2\etc\wxpython\gui_modules\mapdisp.py", line 1159, in
SaveToFile
width, height)
6.4.2\etc\wxpython\gui_modules\mapdisp_window.py", line 575,
in SaveToFile
dc = wx.BufferedPaintDC(self, ibuffer)
   File "C:\Program Files\GRASS 6.4.2\Python27\lib\site-
packages\wx-2.8-msw-unicode\wx\_gdi.py", line 4990, in
__init__
_gdi_.BufferedPaintDC_swiginit(self,_gdi_.new_BufferedPaintD
C(*args, **kwargs))
wx._core
PyAssertionError
C++ assertion "wxAssertFailure" failed at
..\..\src\msw\dcclient.cpp(219) in wxPaintDC::wxPaintDC():
wxPaintDC may be created only in EVT_PAINT handler!
Ticket URL: <http://trac.osgeo.org/grass/ticket/2068&gt;
#2068: Saving the display as an image in wxGUI fails
Component: wxGUI | Version: 6.4.2
Keywords: display | Platform: MSWindows 7
      Cpu: x86-32 |
Changes (by wenzeslaus):
  * keywords: => display
  * component: Default => wxGUI
Comment:
If I remember, this was fixed at some point. Can you please try to update
to GRASS 6.4.3 and test there? (6.4.3 is the current stable release, if
you want to test this bug also for development/svn versions such as GRASS
7 you are welcome, but the update to 6.4.3 may solve your problem.)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2068#comment:1&gt;
      Cpu: x86-32 |
Description changed by martinl:
Old description:
SaveToFile
width, height)
in SaveToFile
__init__
C(*args, **kwargs))
wx._core
PyAssertionError
New description:
SaveToFile
width, height)
in SaveToFile
__init__
C(*args, **kwargs))
wx._core
PyAssertionError
Ticket URL: <http://trac.osgeo.org/grass/ticket/2068#comment:2&gt;
      Cpu: x86-32 |
Comment(by hamish):
as a work-around, you might try the built-in Windows 7 screenshot tool,
  http://windows.microsoft.com/en-US/windows7/products/features/snipping-
tool
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2068#comment:3&gt;
      Type: defect | Status: closed
Resolution: worksforme | Keywords: display
  Platform: MSWindows 7 | Cpu: x86-32
Changes (by laurimyllyvirta):
  * status: new => closed
  * resolution: => worksforme
Comment:
Sorry for missing the new stable release! I can confirm that updating to
6.4.3 fixed this issue for me. And thank you for the lightning speed
responses.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2068#comment:4&gt;
