[GRASS-dev] [GRASS GIS] #2083: Add 3D raster (volume) support to d.legend
Reporter: wenzeslaus | Owner: grass-dev@…
Component: Display | Version: svn-trunk
Keywords: d.legend raster3d | Platform: All
      Cpu: All |
It is not possible to show a legend for 3D raster map.
I have a patch to add support for 3D rasters into `d.legend` module. It is
created in the same way as `r3.colors`, i.e. main.c is turned to the
normal C file and there are two new C files with `int main` functions
which calls the same function but with different parameter.
I used the names `d.legend` and `d.rast3d.legend`.
I'm not sure about non-floating point 3D rasters. There are no integers
but categories are supported? There is actually no documentation about
data types in 3D (see
[http://grass.osgeo.org/grass70/manuals/raster3dintro.html user] and
[http://grass.osgeo.org/programming7/raster3dlib.html programming]
manuals).
The documentation and some comments are still missing but I will add them.
Some basic test would be nice too. The wxGUI support for this will be
added later.
To test the legend use:
# generate data
r3.mapcalc "test_1 = "
# set some color table
r3.colors map=test_1 color=elevation
# use non-gui monitor
# try some legends
d.rast3.legend map=test_1 at=10,50,10,20
d.rast3.legend map=test_1 at=10,50,30,40 use=10,20,50
Ticket URL: <https://trac.osgeo.org/grass/ticket/2083&gt;
      Cpu: All |
Comment(by wenzeslaus):
The name of 3D raster legend module is `d.rast3.legend` not
`d.rast3d.legend`. I misspelled the name in the ticket because I'm really
tired of all `rast3/g3dcell/raster3d/...`
Ticket URL: <https://trac.osgeo.org/grass/ticket/2083#comment:1&gt;
Keywords: d.legend, raster3d | Platform: All
      Cpu: All |
Changes (by hamish):
  * keywords: d.legend raster3d => d.legend, raster3d
Comment:
I don't think this needs a separate module, rather we could add a -3 flag
to the main d.legend module to tell it that it should expect a 3d raster
for the map name. Or if the parser can't be convinced to deal with that,
add a new rast3d= option and check that one or the other has been given
(sort of like g.copy et al.). --> At some point I'd like to have d.legend
support vector maps and arbitrary color rules text files too.
A simple/quick wrapper script way for a linear color scale is to make a
dummy 10x10 cell raster map with both the max and min values from r3.info
put in to some cells with r.mapcalc. Then use d.legend with the dummy 2D
raster map as the input not the real 3D raster cube. fwiw this is why the
v.colors shell script for G6 allows to make a dummy raster map with the
placeholder= option.
see also the r.stack addon module for G6, which was written to allow
'r.colors -e' to work with a series of input maps, in the original case a
3D raster cube split up into individual depth horizons, but a constant
colorbar for all steps in a time series is another common reason to use
it.
  http://grasswiki.osgeo.org/wiki/AddOns/GRASS_6#r.stack
regards,
Hamish
ps- trac wants keywords to be comma separated
Ticket URL: <https://trac.osgeo.org/grass/ticket/2083#comment:2&gt;
      Cpu: All |
Comment(by hamish):
by the way, was the basis for this an idea to show the result of d.legend
on top of the wxgui 3D nviz display? or to be able to screenshot-crop and
paste later for a hardcopy?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2083#comment:3&gt;
      Cpu: All |
Comment(by huhabla):
Replying to [comment:2 hamish]:
> Hi,
flag to the main d.legend module to tell it that it should expect a 3d
raster for the map name. Or if the parser can't be convinced to deal with
that, add a new rast3d= option and check that one or the other has been
given (sort of like g.copy et al.). --> At some point I'd like to have
d.legend support vector maps and arbitrary color rules text files too.
+1 for a single d.legend module with rast3d=, vect= and colrule= options.
Btw: The color rules for raster maps can also be set from a single 3D
raster map using r.colors.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2083#comment:4&gt;
      Cpu: All |
New patch for G7:d.legend added. It adds new option `rast3d` to `d.legend`
and renames option `map` to `rast`. Tested with:
  * `d.mon png`
  * `d.mon wx0`
  * g.gui (2D and 3D)
Patch breaks API (backwards compatibility), so I fixed also wxGUI and
`d.rast.leg` (which I didn't test). wxGUI 2D works the same way as before
including the case of wrong legend parameters (both dialog and legend
disappears but it is possible to show dialog by re-hiding and re-showing
legend). wxGUI 3D works also in the same way (wrong parameters cause
segmentation fault). No explicit support for 3D raster added to GUI, this
would be nice in the future.
GUI section with `rast` and `rast3d` is called `Input`, is that correct?
Please review the patch.
  > d.legend --help
Description:
  Displays a legend for a raster or 3D raster map.
Usage:
  d.legend [-vcnsfs] [rast=name] [rast3d=name] [color=name]
    [lines=value] [thin=value] [labelnum=value] [at=bottom,top,left,right]
    [use=value[,value,...]] [range=min,max] [font=string] [fontscale=value]
    [path=name] [charset=string] [--help] [--verbose] [--quiet]
Parameters:
        rast Name of raster map
                Either this option or rast3d option must be specified
      rast3d Name of 3D raster map
                Either this option or rast option must be specified
I did not tested new legend with other GUI tools. User documentation not
updated yet. To test basic case, use:
# generate data
r3.mapcalc "test_2 = row()"
r3.colors map=test_2 color=elevation
# try some legends
d.legend rast3d=test_2 at=10,50,10,20
d.legend rast3d=test_2 at=10,50,30,40 use=10,20,50
Question: How to get nice error message for 3D raster?
  > d.legend rast=xxxx
ERROR: Raster map <xxxx> not found
  > d.legend rast3d=xxxx
WARNING: Unable to open range file for [xxxx in ]
WARNING: color support for [xxxx] in mapset missing
ERROR: Color file for <xxxx> not available
Ticket URL: <https://trac.osgeo.org/grass/ticket/2083#comment:5&gt;
      Cpu: All |
Please review the patch, interface and tests here and/or test the new
functionality (you can use GUI if you want). I would like to apply the
patch soon and not to risk that some changes in GUI will break it.
Other issue is that it is API break, since I'm replacing `map` by `rast`.
This would be concern if this change would not be applied also to release
branch. Some compatibility options would be possible too if we don't want
to apply this to release branch. (This wouldn't be a problem for the
previous patch which adds completely new module.)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2083#comment:6&gt;
      Cpu: All |
Comment(by hamish):
Replying to [comment:6 wenzeslaus]:
> test the new functionality (you can use GUI if you want).
> I would like to apply the patch soon and not to risk that
it's pretty good, I'll look at merging it ASAP.
> `map` by `rast`. This would be concern if this change would
> not be applied also to release branch.
it's only for grass 7 which isn't released yet, so no problem to change
the module options as long as a grep is done on scripts/, gui/, and grass-
addons/ + html docs to make sure everything else is in sync. The module
command line options for G7 are only hard frozen the day 7.0.0 ships. And
then existing options will be completely frozen for many many years...
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2083#comment:7&gt;
      Cpu: All |
Comment(by hamish):
ok, done in trunk, try >= r60104.
I reworked most of the C code in the patch, but the python stuff was
applied verbatim.
some minor feedback/notes:
  * changed enum defines to be less like official ones in include/*.h. Also
moved them into local_proto.h.
  * to help code readability used TRUE and FALSE for boolean ints. (defined
in gis.h)
  * no need to use {curly} brackets if the statement which follows is a
short one liner.
  * if $(RASTER3DLIB) is added to the Makefile, $(RASTER3DDEP) needs to be
added too.
  * still need to figure out the trick to launch the GUI when no options
are required but some option is required without asking the user to type '
--ui'.
  * I added a new -c flag to `r3.stats` so that the new d.legend '-d'
histogram distribution flag will work for raster3d maps too.
please test.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2083#comment:8&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: d.legend, raster3d
  Platform: All | Cpu: All
Changes (by wenzeslaus):
  * status: new => closed
  * resolution: => fixed
Comment:
Seems to work well (including GUI) in both trunk and 7.0. Closing.
For reference: there was several commits and backports but see for example
r60104, r60379, r60395 and #2303.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2083#comment:9&gt;
