[GRASS-dev] [GRASS GIS] #2088: G7: digitizer python error
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Component: wxGUI | Version: svn-trunk
Keywords: digitizer, python | Platform: Linux
      Cpu: x86-64 |
The wxGUI digitizer shows this problem:
   File "/home/neteler/grass70/dist.x86_64-unknown-linux-
gnu/etc/gui/wxpython/mapwin/buffered.py", line 1025, in
MouseActions
self.OnLeftUp(event)
gnu/etc/gui/wxpython/mapwin/buffered.py", line 1206, in
OnLeftUp
self._onLeftUp(event)
gnu/etc/gui/wxpython/vdigit/mapwindow.py", line 850, in
_onLeftUp
self.OnLeftUpCopyLine(event)
gnu/etc/gui/wxpython/vdigit/mapwindow.py", line 758, in
OnLeftUpCopyLine
nselected = self.bdigit.GetDisplay().SelectLinesByBox((pos1,
pos2))
AttributeError
'VDigitWindow' object has no attribute 'bdigit'
To reproduce it:
  * NC location
  * load and show the "geology" map
  * start the digitizer from the map display window
  * create a new vector map
Note: the "geology" map disappears, "Render map" icon shows it again
  * From "Additional tools": select "Copy feature from (background) vector
map
The error message appears (see above).
Furthermore there is no dialog from which vector map the user could copy
from (should be one of the maps loaded into the layer manager).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2088&gt;
      Cpu: x86-64 |
Comment(by martinl):
Replying to [ticket:2088 neteler]:
> pos2))
> AttributeError
it seems to a typo, should be fixed in r58935.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2088#comment:1&gt;
      Cpu: x86-64 |
A new dialog introduced in r58937. Selecting background map from layer
tree has been disabled.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2088#comment:2&gt;
      Cpu: x86-64 |
should be fixed in r58939 (no idea why this code has such effect). Testing
welcomed. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/2088#comment:3&gt;
Reporter: neteler | Owner: martinl
     Type: defect | Status: assigned
      Cpu: x86-64 |
Changes (by martinl):
* cc: grass-dev@… (added)
  * owner: grass-dev@… => martinl
  * status: new => assigned
Ticket URL: <http://trac.osgeo.org/grass/ticket/2088#comment:4&gt;
      Cpu: x86-64 |
Comment(by wenzeslaus):
Replying to [comment:3 martinl]:
Testing welcomed. Martin
This hiding of layers (not showing rendered layers in map window) happens
a lot, especially with vectors. I have no idea what's behind.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2088#comment:5&gt;
      Cpu: x86-64 |
Replying to [comment:5 wenzeslaus]:
happens a lot, especially with vectors. I have no idea what's behind.
I discovered that `CheckItem()` callled in `AddLayer()`
source:grass/trunk/gui/wxpython/lmgr/layertree.py#L1103 causes that
`Map.layers` appears to be empty (even there are maps in layer tree). I
really have no idea why. Anyway `wx.CallAfter()` avoids it (at least it
seems to)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2088#comment:6&gt;
      Cpu: x86-64 |
Replying to [comment:6 martinl]:
seems to)
So, r58939 fixed the problem I had which occurred when you used `d.vect`
from Command console in GUI or when vector map was output of some module
(and map was added automatically). Thanks.
I agree that `wx.CallAfter()` is probably workaround for some problem but
there is no other option now.
How about the original reported issue? Can we close the ticket?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2088#comment:7&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: digitizer, python
  Platform: Linux | Cpu: x86-64
Changes (by neteler):
  * status: assigned => closed
  * resolution: => fixed
Comment:
The original issue has been fixed, thanks!
Closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2088#comment:8&gt;
