#2091: r.series error in GRASS7 wxGUI
Reporter: richardc | Owner: grass-dev@…
Type: defect | Status: new
Component: wxGUI | Version: unspecified
Keywords: r.series, wxGui | Platform: Linux
Cpu: x86-32 |
The following error occurs when attempting to sum 8 rasters in r.series
from the wxGUI.
However, I'm able to run r.series from the GRASS terminal window.
Richard
GRASS v57721 (on Linux Mint 13/Ubuntu Precise)
File "/home/rcooper/grass7/grass7_trunk/dist.i686-pc-
linux-gnu/etc/gui/wxpython/gui_core/forms.py", line 698, in
OnRun
ret = self._gconsole.RunCmd(cmd, onDone = self.OnDone)
linux-gnu/etc/gui/wxpython/core/gconsole.py", line 497, in
RunCmd
task = GUI(show=None).ParseCommand(command)
linux-gnu/etc/gui/wxpython/gui_core/forms.py", line 2307, in
ParseCommand
Component: wxGUI | Version: svn-trunk
Cpu: x86-32 |
Comment(by annakrat):
Should be fixed in r57950. It's connected to #1808 and #1814, so these
should be fixed now. The problem is that the gui dialog attempts to add
mapset to the map name if missing. But in case of multiple maps the mapset
is considered to be everything after the first @ which can be too long and
then g.findfile crashes. So now it doesn't try to add mapset in case of
multiple maps. It could add mapset for each of the maps but in case of a
lot of maps it could slow down everything and I don't really know if
adding mapsets is needed at all.
