GDAL
October 5, 2013, 5:49am
1
#2093: --interface-description option broken for some commands
Reporter: twsmith | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version:
Keywords: | Platform: Linux
Cpu: x86-32 |
The commands r.mapcalc and r3.mapcalc are missing the --interface
description option in Grass 6.4.3. Trying produces this:
syntax error, unexpected '-', expecting NAME or STRING
Parse error
g.parser --interface-description is also broken, with a different error:
Unable to open script file: No such file or directory
In Grass 7.0.svn, r.mapcalc and r3.mapcalc work properly, but g.parser
produces the same error. I haven't tried 6.4.4, so I don't know about
that.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2093> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
October 5, 2013, 6:48am
2
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.4
Resolution: wontfix | Keywords:
Platform: Linux | Cpu: x86-32
Changes (by martinl):
* status: new => closed
* resolution: => wontfix
* milestone: => 6.4.4
Comment:
Modules `r.mapcalc` and `r3.mapcalc` are the exceptions in GRASS 6. They
don't use the parser. Options are automatically treated as an expression.
In GRASS 7 they use the parser as other commands.
Similarly to `g.parser`, it's the only exception in GRASS 7 which do not
use parser from obvious reasons.
Closing as wontfix.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2093#comment:1> ;
GDAL
October 5, 2013, 9:02am
3
Comment(by neteler):
Sidenote: twsmith, if you need that for anything specific, please contact
the
grass-dev list to find a solution.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2093#comment:2> ;
