[GRASS-dev] [GRASS GIS] #2098: i.vi gari wrong formula?
Reporter: kristinah | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
      Cpu: All |
The formula for GARI in the manual
(http://grass.osgeo.org/grass70/manuals/i.vi.html) seems to be wrong. As
it is now, the result would always be 1.
It is
GARI = ( nirchan - (greenchan-(bluechan - redchan))) /
( nirchan- (greenchan-(bluechan - redchan)))
It should be (e.g. according to
http://www.indexdatabase.de/db/i-single.php?id=363)
( nirchan- (greenchan+(bluechan - redchan)))
As the formula in the manual seems to be taken from code, the code might
be wrong as well. I did not test the function, only read the manual
online.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2098&gt;
From the code:
result = (nirchan - (greenchan - (bluechan - redchan)))/(nirchan - (greenchan - (bluechan + redchan)));
Cpu: All |
It is
online.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2098>
grass-dev mailing list
grass-dev@lists.osgeo.org
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  Platform: Unspecified | Cpu: All
Changes (by ychemin):
  * status: new => closed
  * resolution: => fixed
Comment:
Changed the formula according to the indexdatabase website
Ticket URL: <http://trac.osgeo.org/grass/ticket/2098#comment:1&gt;
Component: Imagery | Version: svn-trunk
Resolution: fixed | Keywords: i.vi
Changes (by neteler):
  * keywords: => i.vi
  * version: unspecified => svn-trunk
  * component: Default => Imagery
  * milestone: 6.4.4 => 7.0.0
Comment:
For the record: r57967 and r57968
Ticket URL: <http://trac.osgeo.org/grass/ticket/2098#comment:2&gt;
      Type: defect | Status: reopened
Resolution: | Keywords: i.vi
Changes (by kristinah):
  * status: closed => reopened
  * resolution: fixed =>
Comment:
Actually, the formula I provided was also wrong. The correct formula has
the "+" in a different position
GARI = ( nirchan - (greenchan- (bluechan - redchan))) /
( nirchan + (greenchan - (bluechan - redchan)))
This was taken from the article where the formula was actually defined:
Gitelson, Anatoly A.; Kaufman, Yoram J.; Merzlyak, Mark N. (1996)
Use of a green channel in remote sensing of global vegetation from EOS-
MODIS
Remote Sensing of Environment 58 (3), 289-298.
DOI: 10.1016/s0034-4257(96)00072-7
When reading the explanation about the meaning of the index in this
article, it became clear to me, that "indexdatabase.de" must be wrong.
Sorry for pointing you in the wrong direction first!
Replying to [ticket:2098 kristinah]:
> It is
online.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2098#comment:3&gt;
Changes (by lucadelu):
  * status: reopened => closed
Comment:
Replying to [comment:3 kristinah]:
MODIS
I update GARI formula in i.vi and related documentation in r58389
I close the ticket, please reopen if needed
Ticket URL: <http://trac.osgeo.org/grass/ticket/2098#comment:4&gt;
