#2102: Digitize doesn't delete records in the attribute table when merging
features.
Reporter: hcho | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: digitizer
Comment (by mlennert):
Replying to [ticket:2102 hcho]:
> I'm not sure if this is an intended behavior of the vector digitizer. I
had 130 features in a vector map and digitized to delete and merge some
features into one. After all this, I expected only one record in the
attribute table, but I still had the 130 (pg driver). Merging multiple
features didn't ask me which record to assign to the new feature, so it
kind of makes sense that the digitizer didn't do anything to the attribute
table because it doesn't know which one to take. Am I supposed to manually
manipulate the attribute table?
I'm not sure this really is a bug. How could GRASS know which attributes
should be kept and which not ? It might be that all attributes are
actually important, even if in a specific map some cat values are not
present. This is a legacy of the cat value as the only attribute in the
old vector formats. I would guess that most people don't use this approach
much, but some might, so I wouldn't change this.
I propose to close this bug as invalid.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2102#comment:2>
