[GRASS-dev] [GRASS GIS] #2103: Make SUBMITTING files more accessible
Reporter: wenzeslaus | Owner: grass-dev@…
     Type: task | Status: new
Component: Docs | Version: svn-trunk
Keywords: submitting, addons, doxygen | Platform: Unspecified
      Cpu: Unspecified |
I think that people are not reading any of SUBMITTING files and the reason
is that they are not available online as HTML or as a part of
documentation. The fact that people don't read the documentation, makes
this ticket some kind of critical.
Currently SUBMITTING files are just plain text files in source code.
Online availability is only Trac file view which displays them again as
plain text file. They are available offline when you download source codes
but not everybody is used to look at the traditional files in the source
root directory such as SUBMITTING. The same applies to main source code
and to addons.
There are two highly connected sub-tickets: syntax and publishing.
Files can become part of the main web site, part of Doxygen documentation
(or potentially other programming documentation) or be stand alone (web)
pages.
I can see only three possibilities in the syntax. Complete HTML, HTML part
(same as manual pages), Markdown, reStructuredText.
Complete HTML is easy for publishing. HTML part can be integrated with
Doxygen or processed using GRASS manual tools. Markdown can be integrated
with Doxygen or processed using some 3rd party tools. reStructuredText
cannot be integrated with anything which is in GRASS but it is a Python
(almost) standard and it can by integrated with potential Sphinx
documentation or processed using 3rd party tools just as Markdown would
be.
If I understand correctly (but somebody might want to check this), HTML,
Markdown and reStructuredText can be rendered by Trac into HTML page just
by setting the right properties, so this would take care of online
publishing.
Markdown and reStructuredText are close to the current plain text syntax
(there are some headings and bullet list already) and of course, there is
the advantage of these formats that they look nice by themselves.
I was not diving deeply into various possibilities, I think we need to at
least partially agree on approximate directions first.
Note that there are also some other files similar in way that they a just
plain text files in the source code:
  * source:grass/trunk/README
  * source:grass/trunk/INSTALL
  * source:grass/trunk/TODO (last change 5 year ago)
  * source:grass-addons/README
  * source:grass-addons/SVN_HOWTO.txt
These might need the same changes too. Maybe also other files might be
part of this category:
  * source:grass/trunk/AUTHORS
  * source:grass/trunk/COPYING
  * source:grass/trunk/GPL.TXT
  * source:grass/trunk/CHANGES (last change 8 year ago)
For some files similar changes were already done:
  * source:grass/trunk/REQUIREMENTS.html
  * source:grass/trunk/translators.csv
  * source:grass-addons/contributors.csv
Ticket URL: <http://trac.osgeo.org/grass/ticket/2103&gt;
      Cpu: Unspecified |
Comment(by wenzeslaus):
To make the list and currently used possibilities complete, here is a link
to rfc diretcory which contains all the RFC/PSC documentes:
  * source:grass/trunk/rfc
The documents are in half-Doxygen half-Markdown syntax which is processed
by Doxygen and the result is here:
  * http://grass.osgeo.org/programming7/psc_motions.html
  * http://grass.osgeo.org/programming7/RFC.html
And to make decision about syntax even harder: we are using also Media
wiki and Trac wiki/tracker with their specific syntaxes. This was also
discuss at grass-dev [http://lists.osgeo.org/pipermail/grass-
dev/2013-May/063625.html Using "trac" is difficult] ([http://osgeo-
org.1560.x6.nabble.com/Using-quot-trac-quot-is-difficult-td5041757.html
nabble], [http://comments.gmane.org/gmane.comp.gis.grass.devel/51981
gmane]).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2103#comment:1&gt;
      Cpu: Unspecified |
When looking at similar files, I completely over looked the whole ``doc``
directory:
  * source:grass/trunk/doc
I would like to have a look at this but I don't know when I will be able
to do it, so I encourage others to think about it, too. Moreover, I want
to avoid situation when I will explore, for example reStructuredText +
Sphinx solution and than will realize that public opinion is to have
everything in HTML only.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2103#comment:2&gt;
      Type: task | Status: closed
Resolution: fixed | Keywords: submitting, addons, doxygen
  Platform: Unspecified | Cpu: Unspecified
Changes (by wenzeslaus):
  * status: new => closed
  * resolution: => fixed
Comment:
* All `SUBMITTING` files were converted to Trac wiki:Submitting pages
(r61014).
   - wiki:Submitting/General
   - wiki:Submitting/C
   - wiki:Submitting/Python
   - wiki:Submitting/wxGUI
   - wiki:Submitting/Docs
  * All RFC documents were also moved to Trac wiki:RFC pages (r60890).
  * `SUBMITTING` files in addons tracked in #2104.
  * The [source:grass/trunk/doc doc] directory remains unresolved.
  * Various files may stay in their plain text form and only in source
code.
   - source:grass/trunk/AUTHORS
   - source:grass/trunk/COPYING
   - source:grass/trunk/GPL.TXT
   - source:grass/trunk/CHANGES (last change 8 year ago)
  * `README` files here and there in the source code probably don't need
any markup or publication.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2103#comment:3&gt;
