[GRASS-dev] [GRASS GIS] #2108: default temporal database
Reporter: lucadelu | Owner: grass-dev@…
     Type: defect | Status: new
Component: Temporal | Version: svn-trunk
Keywords: connect | Platform: All
      Cpu: Unspecified |
the default temporal database is in
$GISDBASE/$LOCATION_NAME/PERMANENT/tgis/sqlite.db, I already spoken with
Soeren to move it in $GISDBASE/$LOCATION_NAME/PERMANENT/sqlite/tgis.db but
there are some limitation on the access of space time datasets
Ticket URL: <http://trac.osgeo.org/grass/ticket/2108&gt;
      Cpu: Unspecified |
Comment(by lucadelu):
Sorry I would like to move the db in
$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/tgis.db
Ticket URL: <http://trac.osgeo.org/grass/ticket/2108#comment:1&gt;
      Cpu: Unspecified |
Comment(by huhabla):
The reason to put the temporal database by default in the PERMANENT mapset
is an ongoing discussion in ticket #2110.
However, the temporal database should not be placed in the same folder as
the vector attribute database [1].
[1] http://lists.osgeo.org/pipermail/grass-dev/2012-December/061138.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/2108#comment:2&gt;
      Type: defect | Status: closed
Resolution: duplicate | Keywords: connect
  Platform: All | Cpu: Unspecified
Changes (by lucadelu):
  * status: new => closed
  * resolution: => duplicate
Comment:
Replying to [comment:2 huhabla]:
mapset is an ongoing discussion in ticket #2110.
Also this ticket #2258 is speaking of the same problem
as the vector attribute database [1].
I'm going to close this ticket, follow the discussion in the other
tickets.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2108#comment:3&gt;
