[GRASS-dev] [GRASS GIS] #2109: connect error in replacement of $MAPSET
Reporter: lucadelu | Owner: grass-dev@…
     Type: defect | Status: new
Component: Temporal | Version: svn-trunk
Keywords: connection | Platform: All
      Cpu: All |
when I try to use a different mapset then PERMANENT using $MAPSET variable
it is not changed with the right value but a $MAPSET directory is create
on the location path
Ticket URL: <http://trac.osgeo.org/grass/ticket/2109&gt;
      Cpu: All |
Comment(by huhabla):
You can use:
eval `g.gisenv`
To set $GISDBASE, $LOCATION_NAME and $MAPSET
I will modify the code of t.connect so that instead of the shell variables
$GISDBASE and $LOCATION_NAME the real path variables are set in the module
help to reduce confusion.
t.connect accepts as database argument a string that defines a database
connection. In case of sqlite this must be a path. t.connect will not
substitute shell variables itself if they are not set.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2109#comment:1&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: connection
  Platform: All | Cpu: All
Changes (by huhabla):
  * status: new => closed
  * type: defect => enhancement
  * resolution: => fixed
Comment:
Replying to [comment:1 huhabla]:
> You can use:
> eval `g.gisenv`
variables $GISDBASE and $LOCATION_NAME the real path variables are set in
the module help to reduce confusion.
Done in r58015
Ticket URL: <http://trac.osgeo.org/grass/ticket/2109#comment:2&gt;
      Type: enhancement | Status: reopened
Resolution: | Keywords: connection
Changes (by lucadelu):
  * status: closed => reopened
  * resolution: fixed =>
Comment:
Replying to [comment:2 huhabla]:
> > You can use:
> > eval `g.gisenv`
> Done in r58015
Sorry I don't understand what was done, I have the same behavior of
yesterday, If I use
t.connect database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/tgis.db'
the database is created in
/grassdata/eu_laea/$MAPSET/sqlite/tgis.db
The revision I'm using is 58021.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2109#comment:3&gt;
This issue is hopefully fixed in r58024.
Now the temporal framework supports '$GISBASE/$LOCATION_NAME/$MAPSET'
settings and will substitute them correctly. t.connect should show now the
same behavior as db.connect.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2109#comment:4&gt;
  * status: reopened => closed
Comment:
Replying to [comment:4 huhabla]:
Fixed, thanks a lot
Ticket URL: <http://trac.osgeo.org/grass/ticket/2109#comment:5&gt;
