[GRASS-dev] [GRASS GIS] #2110: error registering maps outside mapset
Reporter: lucadelu | Owner: grass-dev@…
     Type: defect | Status: new
Component: Temporal | Version: svn-trunk
Keywords: register | Platform: All
      Cpu: All |
if I try to register raster (but I think also vector and raster3d) maps
outside my mapset I obtain error because the raster map is not found.
I think to have fixed it with the attached patch, please try it.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2110&gt;
      Cpu: All |
Comment(by huhabla):
The current behavior is a design decision. Space time datasets accept only
maps from the same mapset for registration. A new space time datasets will
be dedicated to the current mapset. The current mapset is part of its
temporal database identifier. Hence space time datasets from different
mapsets can be stored in the same temporal database. This assures that
mapsets can share the same temporal database.
Space time datasets are new datatypes in GRASS and should behave like
raster or vector maps. Hence these datatypes are mapsets specific. It is
possible to access space time datasets from different mapsets for reading,
if the mapsets share the same temporal database. But it should not be
possible to modify space time datasets from different mapsets.
As default the temporal database will be created in the PERMANENT
directory, so that space time datasets and maps from different mapsets can
be registered there. This allows the read only access to the datasets from
different mapsets in the temporal database. To avoid this, the temporal
database can be set mapset specific. Hence each mapset sees only their
space time datasets and registered maps.
This decision was made to reduce confusion, to avoid unexpected behavior
and to assure a convenient behavior of the temporal framework in the GRASS
way.
Examples to support this decision:
If you register maps from a foreign mapset in a space time raster dataset
and you remove the maps in the foreign mapset, then the temporal database
might not be aware of these changes, pointing to maps that have not been
unregistered. In all following operations the effected space time datasets
will produce errors.
If you use "t.remove" with the "-rf" option, the provided space time
datasets and its registered maps will be removed from the temporal and
spatial database (g.remove will be called). This operation will fail if
the registered maps are from different mapsets.
Attention when several mapsets share the same temporal database:
It is still a work in progress to grant only access to space time datasets
and raster maps in the temporal database, that the user has permission to
read --> configured using the GRASS mapset permission system. Hence you
might see space time datasets in the output of "t.list" from different
mapsets, to which you have no permission to access.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2110#comment:1&gt;
      Cpu: All |
Comment(by annakrat):
I ran into problems when I tried to register maps from different mapsets:
although t.register reported that it couldn't register the maps into the
dataset (which is ok according to the desicion), it seemed to register
them into the database. Because then, I switched to that mapset and tried
to register the maps again with a new dataset but it failed because the
maps were already registered (--o helped). I guess the maps should not
have been registered at all?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2110#comment:2&gt;
      Cpu: All |
Replying to [comment:2 annakrat]:
mapsets: although t.register reported that it couldn't register the maps
into the dataset (which is ok according to the desicion), it seemed to
register them into the database. Because then, I switched to that mapset
and tried to register the maps again with a new dataset but it failed
because the maps were already registered (--o helped). I guess the maps
should not have been registered at all?
That is correct, this check was not implemented.
I have hopefully solved this issue with commit r58020. Many thanks for the
feedback.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2110#comment:3&gt;
      Cpu: All |
Comment(by lucadelu):
Replying to [comment:1 huhabla]:
only maps from the same mapset for registration. A new space time datasets
will be dedicated to the current mapset. The current mapset is part of its
I'm not sure that this is the right way to follow because PERMANENT may be
owned by a user differing from the user that is going to create a new
temporal database in the location (think multi-user location!) so there
should arise a write permission problem.
For example, in the location where our group members store MODIS LST data,
when the user MarkusN previously connected his data to the temporal
framework, but myself I also connect to it later (here MarkusN's data are
hence in PERMANENT) I can do that. But when I try to actually create a new
temporal dataset I obtain this error:
t.connect -d
Default driver / database set to:
driver: sqlite
database: /grassdata/eu_laea/PERMANENT/tgis/sqlite.db
t.create out=lst_2003 title=lst_2003 description="LST 2003 dataset"
ERROR: Unable to execute transaction:
        INSERT INTO strds_base ( name ,creator ,mapset ,creation_time
        ,temporal_type ,id ,semantic_type ) VALUES ('lst_2003' ,'lucadelu'
        ,'lucadelu_test_temporal' ,'2013-10-17 10:33:20.660192' ,'absolute'
        ,'lst_2003@lucadelu_test_temporal' ,'mean') ;
        INSERT INTO strds_absolute_time ( start_time ,end_time ,granularity
        ,timezone ,id ,map_time ) VALUES (NULL ,NULL ,NULL ,NULL
        ,'lst_2003@lucadelu_test_temporal' ,NULL) ;
        INSERT INTO strds_spatial_extent ( north ,bottom ,west ,top ,proj
        ,east ,id ,south ) VALUES (NULL ,NULL ,NULL ,NULL ,'XY' ,NULL
        INSERT INTO strds_metadata ( max_min ,description ,ewres_min ,title
        ,min_max ,nsres_min ,nsres_max ,number_of_maps ,raster_register
        ,command ,min_min ,ewres_max ,id ,max_max ) VALUES (NULL ,'LST 2003
        dataset' ,NULL ,'lst_2003' ,NULL ,NULL ,NULL ,NULL ,NULL ,'#
        2013-10-17 10:33:20
        t.create out="lst_2003" title="lst_2003"
        ' ,NULL ,NULL ,'lst_2003@lucadelu_test_temporal' ,NULL) ;
   File "/home/lucadelu/compilati/grass7/dist.x86_64-unknown-linux-
gnu/scripts/t.create", line 83, in <module>
     main()
gnu/scripts/t.create", line 79, in main
     semantic, None, grass.overwrite())
gnu/etc/python/grass/temporal/open.py", line 169, in
open_new_space_time_dataset
     sp.insert(dbif)
gnu/etc/python/grass/temporal/abstract_dataset.py", line 395, in insert
     dbif.execute_transaction(statement)
gnu/etc/python/grass/temporal/core.py", line 628, in execute_transaction
     self.cursor.executescript(statement)
sqlite3.OperationalError: attempt to write a readonly database
It is naturally "read-only" because PERMANENT is owned by MarkusN and not
by me.[[BR]]
Another example: I try to create a new temporal DB in another location
which yet does not contain any temporal DB, but the owner of PERMANENT is
again MarkusN, I get this error:
t.connect -d
driver: sqlite
database: /grassdata/patUTM32/PERMANENT/tgis/sqlite.db
Create temporal database: /grassdata/patUTM32/PERMANENT/tgis/sqlite.db
     main()
gnu/scripts/t.create", line 76, in main
     tgis.init()
gnu/etc/python/grass/temporal/core.py", line 298, in init
     create_temporal_database(dbif, database)
gnu/etc/python/grass/temporal/core.py", line 371, in
     os.makedirs(tgis_dir)
   File "/usr/lib/python2.7/os.py", line 157, in makedirs
     mkdir(name, mode)
OSError: [Errno 13] Permission denied:
'/grassdata/patUTM32/PERMANENT/tgis'
So, t.create fails because I cannot write there due to the permission
management, say, PERMANENT is not and should not be group writable.
way.
It is unexpected behaviour since it is contrary to the long-term known
GRASS permission management.
dataset and you remove the maps in the foreign mapset, then the temporal
database might not be aware of these changes, pointing to maps that have
not been unregistered. In all following operations the effected space time
datasets will produce errors.
The same would apply to imagery groups, but this implementation is there
for many years without real problems. Similar also for r.external and
r.reclass.area. It is unavoidable that a user takes care of the data
management. This should not limit the overall usability, hence more
flexibility is better.
I understand to some extent your design decision but I see here a big
problem for people with a shared data storage infrastructure like in our
group (FEM PGIS).
For example, MarkusM is reconstructing MODIS LST data and he is at this
point the owner of the mapset in which the results are stored. This
mapset's size is of several TB and I have to work with the entire dataset
(time series). We cannot change the owner of that mapset because it is
continuously updated through an automated procedure.
Until now we cannot use temporal framework in our Unit, for my point of
view this is really a limitation. Please consider to add the possibility
to work with maps outside the working mapset and I'll be able to continue
to test the temporal framework.
Thanks
Luca
Ticket URL: <http://trac.osgeo.org/grass/ticket/2110#comment:4&gt;
      Cpu: All |
Replying to [comment:4 lucadelu]:
be owned by a user differing from the user that is going to create a new
If you have a multi-user mapset environment, then you have to take care
where to put the temporal database that should be accessed by several
users from different mapsets. You can simply put the temporal database
into a directory to which your group of users has write permissions? You
can use PostgreSQL as temporal database, then you have to take care about
user access permissions at the server as well. You don't depend on the
default settings. However, i can change the default location of the
temporal database to be mapset specific if everyone agrees.
But, changing this default behavior results in the drawback that the
temporal database will be created for each mapset separately. Hence the
user will not be able to see space time datasets from other mapsets. This
is a principal problem of the SQL database Python interface. It is not
possible to merge several sqlite databases to a single one and open them
at once. This is AFAIK also not possible with the PostgreSQL backend.
Different mapsets must share a single database to be able to see the space
time datasets of each other.
I would love to see a solution of multi-database management to fix this
issue.
The temporal database approach is different from the vector database
approach, where each vector has its own metadata file that describes the
database connection for each layer. This approach can not be applied to
the temporal database design, otherwise i need to create a database
metadata connection file for each map and space time dataset. Hence if you
want to access the temporal metadata information for 10000 maps, then you
need to visit 10000 metadata files, connect 10000 times to the databases
and read information for each map. Simple SQL where conditions would take
hours to process. Sorting and many other features would not be available
as SQL query. This approach would simply not work.
Hence, if the user wants to access space time datasets from different
mapsets, then the temporal database path in each of these mapsets must
point to single writable database location (sqlite -> path, postgresql ->
server).
data, when the user MarkusN previously connected his data to the temporal
[snip]
not by me.[[BR]]
This will fail even if the temporal frameworks allows that you can
register maps from different locations in a space time dataset in your
current location.
In your case the registration process will modify the metadata of the
raster maps in MarkusN location, it will try to set the time stamps for
the maps. And because you have no write permission this will fail.
Space time datasets and their content are mapset specific, maps will be
modified if you register them in the temporal database. It is IMHO an
important functionality. It assures that you have access to the map time
stamps using the C libraries.
[snip]
behavior and to assure a convenient behavior of the temporal framework in
the GRASS way.
I agree that putting the temporal database by default into the PERMANENT
mapset might not be the most agreeable solution. But the design decision
that space time datasets and their content are mapset specific follows the
group (FEM PGIS).
In this case the automated procedure should update the space time datasets
that manages the time series in the mapset of MarkusM? If the temporal
database connection of the mapset from MarkusM and your mapset point to
the same SQL database, then you can access the updated space time
datasets.
> Thanks
> Luca
I hope i could explain the design decision a bit better. Of course, if you
have arguments that make my completely obsolete, then we can change the
design. But so far i don't see a reason to change this. :slight_smile:
Best regards and many thanks for this discussion, we should have had it in
the design phase of the temporal framework :wink:
Soeren
Ticket URL: <http://trac.osgeo.org/grass/ticket/2110#comment:5&gt;
      Cpu: All |
I have discussed this topic off the list with Luca and investigated the
problem in more detail. Luca suggested to register only maps from foreign
mapsets that are not already in the temporal database and that have a
timetsamp attached with r.timestamp, so that there is no need anymore to
modify the timestamp in the spatial database metadata. Revision r58084
allows now to use existing time stamps in the registration process that
were set with (r|r3|v).timestamp. This works only if the map is not
already registered in the temporal database. However, timestamps will be
rewritten in the spatial database metadata, since the registration method
is generic and does not care where the timestamps originated from.
A more fundamental problem that occurs when registering maps from foreign
mapsets is the following:
Space time datasets are defined by the spatio-temporal extents and the
metadata of their maps. Hence, if you modify a map, then you will modify
the space time datasets in which this map is registered. That's one reason
why space time datasets are mapset specific.
Consider to have a work-mapset A and foreign mapset B. Now you register
maps from mapset B in a space time dataset of mapset A. Now the owner of
mapset B creates several space time datasets in his mapset and modifies
some maps that are registered in the space time dataset of mapset A using
the temporal framework (t.snap, t.shift, ...). The metadata modification
of maps in mapset B will result in the modification of the space time
dataset in mapset A. Hence the owner of mapset B can compromise the space
time datasets of the owner of mapset A. This will violate the GRASS
permission system, hence, its not allowed will be prevented by the
temporal framework.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2110#comment:6&gt;
