[GRASS-dev] [GRASS GIS] #2111: r.texture: allow use of cover map to define window, instead of only fixed-size pixel windows
size pixel windows
Reporter: mlennert | Owner: grass-dev@…
Component: Raster | Version: svn-trunk
Keywords: r.texture cover map | Platform: Unspecified
      Cpu: Unspecified |
It would be great if r.texture could offer the option to not define a
fixed-sized moving window (defined by number of pixels to a side) but to
calculate the indices for variable sized polygons defined by a (vector or
raster) cover map. If the cover map is vector, it would be great to have
r.texture fill up the attribute table with the requested indices.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2111&gt;
size pixel windows
Keywords: r.texture cover map r.statistics | Platform: Unspecified
      Cpu: Unspecified |
Changes (by mlennert):
  * keywords: r.texture cover map => r.texture cover map r.statistics
Comment:
Replying to [ticket:2111 mlennert]:
Maybe this would actually fit better into r.statistics ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2111#comment:1&gt;
