#2114: m.nviz.image does not work on Windows
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.2
Component: LibOpenGL | Version: svn-trunk
Resolution: | Keywords: m.nviz.image
CPU: Unspecified | Platform: All
Comment (by hcho):
This specific issue on Linux is fixed by r72939.
Replying to [comment:8 wenzeslaus]:
> This now seems to be an issue on Linux as well. On Ubuntu 16.04:
> > m.nviz.image elevation_map=elevation output=test format=ppm
size=640,480
> X Error of failed request: BadValue (integer parameter out of range for
operation)
> Major opcode of failed request: 154 (GLX)
> Minor opcode of failed request: 3 (X_GLXCreateContext)
> Value in failed request: 0x0
> Serial number of failed request: 24
> Current serial number in output stream: 29
> Changing platform to all. New ticket more appropriate? New
implementation seems to be necessary.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2114#comment:11>
