#2116: r.kappa: call to r.stats fails if spaces in path
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Default | Version: svn-releasebranch64
Keywords: kappa path | Platform: Unspecified
Cpu: Unspecified |
Comment(by hamish):
Replying to [ticket:2116 mlennert]:
> The attached patch solves the problem for me, but I imagine that
> there is a more elegant solution.
right, we should use G_vspawn_ex() instead of system(). It's already done
for r.kappa in G7; just needs to be backported & tested. see r40146 and
r44964.
In addition, as a minor style tweak/simplification I'd suggest to consider
using the r.stats output= file option instead of a shell redirect/dealing
with the stdout pipe.
Component: Raster | Version: svn-releasebranch64
Keywords: r.kappa, path | Platform: Unspecified
Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:3 hamish]:
> simple quoting fix committed in devbr6 & relbr64 with r58111,2.
> it should be tested in wingrass before closing the ticket, see the
i.smap help page for an example.
Thanks a lot ! I hadn't applied the patch, yet, since you suggested
G_vspawn_ex(), and I didn't find the time to look into that. Should that
solution be preferred ? Should we maybe leave the ticket open as a
reminder, or should we just say that if it works in windows we're happy
with this quick fix for grass6 ?
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:4 mlennert]:
> I hadn't applied the patch, yet, since you suggested G_vspawn_ex(), and
I didn't find the time to look into that. Should that solution be
preferred ?
The spawn functions are preferable (that's what r.kappa uses in 7.0), as
they avoid the shell altogether.
Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:5 glynn]:
and I didn't find the time to look into that. Should that solution be
preferred ?
Backported to 6.5 in r60121 and to 6.4 in r60122. The result is identical
7.0.
Replying to [comment:6 neteler]:
preferred ?
as they avoid the shell altogether.
identical 7.0.
> Please test on Windows and close if solved.
Just tested on Windows 7 Virtual Machine with
WinGRASS-6.4.4svn-r60212-962-Setup.exe (yesterday's build) and GISDBASE
containing "GRASS DATA": it seems to work perfectly.
