[GRASS-dev] [GRASS GIS] #2119: wxgui: attribute table manager fails with "Inconsistent number of columns in the table"
in the table"
Reporter: mlennert | Owner: grass-dev@…
     Type: defect | Status: new
Component: wxGUI | Version: svn-trunk
Keywords: table manager | Platform: Unspecified
      Cpu: Unspecified |
After having filled the attribute table of polygons resulting from
segmentation with a whole series of variables, I get the following error
when trying to display the attribute table:
"Error in v.db.s..."
and then
This comes from the test at line 249 in gui/wxpython/dbmgr/base.py. Adding
some print statements I can see that while there are 159 columns, the gui
only detects 97 fields in the actual record (second to last record of the
table).
Using v.db.select from the GUI or at the command line I can see all lines
without any problems.
Printing out the record on which the GUI fails, after it went through
record = record.split(fs)
I see the following at the 97th field:
'0.014715{_sep_'
and nothing after that.
All the fields before that are correct.
When I export the file to shp and the reimport it again, I get a similar
error, but this time it happens on the last record, record length is 88,
and the record in that line is normal, without the '{_sep_'.
I'll attach the shapefile to the ticket.
Any hints ?
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2119&gt;
in the table"
      Cpu: Unspecified |
Comment(by mlennert):
Since the shapefile is too big to attach it here, you can get it from:
[http://tomahawk.ulb.ac.be:8014/segtest.tgz\]
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2119#comment:1&gt;
in the table"
      Cpu: Unspecified |
Comment(by annakrat):
I didn't have any problems with loading the table in attribute manager,
all columns seem to be there. I am running Ubuntu with US locale. The
'`{__sep__}`' is the the separator which is used internally for
v.db.select because it's highly improbable that it could appear in the
data. Strange is that you can see only a part of the separator without the
one curly bracket. Are you running it on Windows?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2119#comment:2&gt;
in the table"
      Cpu: Unspecified |
Replying to [comment:2 annakrat]:
No, Debian. Locale=fr_BE.UTF-8, but I just tried with setting to C and
relaunching the GUI and I get the same error. Also in grass64release.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2119#comment:3&gt;
