#2122: v.to.db: new variables to add
Reporter: mlennert | Owner: grass-dev@…
Priority: normal | Milestone: 7.4.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.to.db eigenvalues bbox
CPU: All | Platform: All
Comment (by mlennert):
Replying to [comment:8 mlennert]:
> I've just attached a patch that implements a bounding box measure in
v.to.db.
> However, at this stage, it doesn't, yet, take into account the case when
there is more than one polygon with the same category.
I just uploaded a modified version of the patch to take this into account
(although I think a warning would be appropriate for the case of multiple
features with the same cat and '-p' flag set, but that is a different
issue).
Please test. If it works for you then I can commit it to trunk for wider
testing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2122#comment:10>
