[GRASS-dev] [GRASS GIS] #2128: t.vect.observe.strds vector output wirte values in the same layer
Reporter: lucadelu | Owner: grass-dev@…
Component: Temporal | Version: svn-trunk
Keywords: t.vect.observe.strds output | Platform: Other Unix
      Cpu: Unspecified |
Now t.vect.observe.strds is writing the results of the vector_output in
several layer, I would like to add possibility to write all the outputs in
the first layer in different columns .
Ticket URL: <http://trac.osgeo.org/grass/ticket/2128&gt;
      Cpu: Unspecified |
Comment(by huhabla):
I would suggest to implement this functionality into a new module called
v.what.strds, since the output is a vector map and not a space time vector
dataset or time stamped tables of a vector map. The implementation would
be different from t.vect.observe.strds because the column names must be
generated from the time stamps and v.what.rast must be called to fill each
column.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2128#comment:1&gt;
Reporter: lucadelu | Owner: lucadelu
      Cpu: Unspecified |
Changes (by neteler):
* cc: grass-dev@… (added)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2128#comment:3&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: t.vect.observe.strds output
       CPU: Unspecified | Platform: Other Unix
Changes (by lucadelu):
* status: new => closed
* resolution: => fixed
Comment:
v.what.strds moved from addons to trunk in r65686.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2128#comment:4&gt;
