[GRASS-dev] [GRASS GIS] #2133: g.parser does call the form.py with full path
Reporter: wenzeslaus | Owner: grass-dev@…
     Type: defect | Status: new
Component: wxGUI | Version: svn-trunk
Keywords: parser | Platform: All
      Cpu: All |
When I run `gui/wxpython/gui_core/forms.py` directly with full path:
python gui_core/forms.py ../../temporal/t.list/t.list.py
I get the module form/dialog (task frame) for the command and following
debug output (`g.gisenv set=WX_DEBUG=1`):
GUI D1/1: forms.py called using command: ../../temporal/t.list/t.list.py
GUI D1/1: forms.py opening form for: ['t.list.py']
However, when I run the module itself (here with `--ui` because of other
parameters):
../../temporal/t.list/t.list.py --ui
I don't get the GUI for module, I get an error dialog with message:
Unable to fetch interface description for command 't.list.py'.
Details: [Errno 2] No such file or directory
Try to set up GRASS_ADDON_PATH or GRASS_ADDON_BASE variable.
and the reason is actually clear from the debug output:
GUI D1/1: forms.py called using command: t.list.py type="strds"
temporaltype="absolute,relative" order="id" columns="id"
GUI D1/1: forms.py opening form for: ['unknown']
The parser mechanism does not pass the full path to file, so it is not
found by the `task.py` mechanism. The task.py should probably end with
some other error then setting the name to `unknown` but that's another
story.
The function responsible for running GUI is `module_gui_wx` in
`lib/gis/parser.c`. It is passing result of `G_recreate_command()` as a
first parameter and this works pretty well. The problem is that it returns
only base name of the command returned by `G_program_name()` which uses
global variable set by `G_set_program_name` function which stripes the
name to using `G_basename` function.
I cannot go further because `G_recreate_command` does not have any useful
documentations (the only line of doc is related to non-interactivity which
is really outdated). I hope that some others knows what is the concept of
this and so what is the right solution.
This functionality is important for testing non-core modules
(addons/extensions) and more importantly it is crucial for running user
scripts or scripts distributed in other way then GRASS Addons repository.
Note that you need at least r58212 (GRASS 7) to test this because I added
the debug messages in r58212. By the way, I've fixed the two tests there
and extended usage suggestions when you run it without parameters.
*This is the second Trac component I'm suggesting in past few weeks but
what about Parser/G_parser/GRASS Parser/g.parser component*.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2133&gt;
Component: Parser | Version: svn-trunk
      Cpu: All |
Changes (by hamish):
  * component: wxGUI => Parser
Comment:
Replying to [ticket:2133 wenzeslaus]:
> weeks but what about Parser/G_parser/GRASS Parser/g.parser
> component*.
done.
regards,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2133#comment:1&gt;
      Cpu: All |
Comment(by hamish):
ps- typically scripts using g.parser need to be somewhere in the system
PATH since they run in two passes, and the second time it has forgotten
the original path (if it ever knew it, it could have been called as
"./script"). For compiled addon modules they don't need to be in the PATH
since the module is run in the same process as the parser.
try adding the directory you script is in to the PATH.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2133#comment:2&gt;
