#2133: g.parser does call the form.py with full path
Reporter: wenzeslaus | Owner: wenzeslaus
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Parser | Version: svn-trunk
Resolution: | Keywords: parser, forms, wxGUI
CPU: All | Platform: All
Changes (by wenzeslaus):
* owner: grass-dev@… => wenzeslaus
* keywords: parser => parser, forms, wxGUI
* milestone: 7.0.0 => 7.1.0
Comment:
This is still an issue. Custom Python scripts using
`grass.script.parser()` won't open a GUI from the command line. You will
get (tested on a copy of t.list, i.e. something on "on PATH"):
Unable to fetch interface description for command 't.list2'.
Details: [Errno 2] No such file or directory
Try to set up GRASS_ADDON_PATH or GRASS_ADDON_BASE variable.
But there is no reason for modifying any path variables, you provided full
(or relative) path, so this should be enough. In GUI Console, you will get
the GUI dialog/form but running the module will show a run in the dialog's
Command output tab but `[Errno 2] No such file or directory` in the main
GUI's Console (I'm not sure what is the exact mechanism in GUI).
Removing the `G_basename` calls and directory stripping from
`G_set_program_name()` makes it work both in command line and the GUI.
#!diff
Index: lib/gis/parser.c
--- lib/gis/parser.c (revision 67989)
+++ lib/gis/parser.c (working copy)
@@ -340,8 +340,6 @@
- G_basename(tmp_name, "exe");
- st->pgm_name = tmp_name;
Index: lib/gis/progrm_nme.c
--- lib/gis/progrm_nme.c (revision 67989)
+++ lib/gis/progrm_nme.c (working copy)
@@ -44,18 +44,8 @@
- i = strlen(s);
- while (--i >= 0) {
- if (G_is_dirsep(s[i])) {
- s += i + 1;
- break;
/* strip extension from program name */
- temp = G_store(s);
- G_basename(temp, "exe");
- G_basename(temp, "py");
name = G_store(s);
Extensions are probably present on MS Windows and we don't want them in
history (r21674, r62904). But I have no idea why we are stripping the
directories (blame goes to r9499).
Is there a occasion when modules are called with full path? Maybe MS
Windows e.g., without `shell=True` in Python? Or can we just preserve path
when it is present and leave the extension there as well? (Resulting in
`G_program_name()` returning whatever was there, putting it into history
and passing it to GUI.)
Alternatively, we can add another function which will return the
originally used path and will be used in `module_gui_wx()` (in `parser.c`)
instead of `G_program_name()`. This will leave the history behavior intact
(you will get stripped name although you provided a full path) but the GUI
will get the full (or relative) path needed to run the script to obtain
the interface and execute script later.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2133#comment:3>
