[GRASS-dev] [GRASS GIS] #2138: winGRASS6.4.svn - addon python script status?
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: blocker | Milestone: 6.4.4
Component: Addons | Version: unspecified
Keywords: wingrass, addon, python | Platform: MSWindows 7
      Cpu: x86-64 |
regarding 6.4.4 planning
http://lists.osgeo.org/pipermail/grass-dev/2013-November/066351.html
some tests for addon python scripts:
System Info
GRASS Version: 6.4.4svn
GRASS SVN Revision: 58275
GIS Library Revision: 50937 (2012-02-25)
GDAL/OGR: 1.10.1
PROJ4: Rel. 4.8.0, 6 March 2012
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
structure of the addon-folder in winGRASS6.4.svn:
bin <= python script related bat-files are here
docs
man
modules.xml
r.basin.py
r.ipso.py
r.stream.angle.exe
r.stream.basins.exe
r.stream.del.exe
r.stream.distance.exe
r.stream.extract.exe
r.stream.order.exe
r.stream.pos.exe
r.stream.stats.exe
r.wf.py
the python script related bat-files are here are in the bin-folder, but
the addon\bin isn't in the %GRASS_ADDON_PATH%
the content of r.basin.py.bat:
@"%GRASS_SH%" "%GISBASE%/scripts/r.basin.py" %*
%GRASS_SH% can't start python scripts.
so python script aren't working with winGRASS6.4.SVN
now testing with winGRASS6.5.svn
System Info
GRASS Version: 6.5.svn
GRASS SVN Revision: 58286
GIS Library Revision: 50936 (2012-02-25)
GDAL/OGR: 1.10.1
Python: 2.7.4
wxPython: 2.8.12.1
Fetch & install extension from GRASS Addons
structure of the addon-folder in winGRASS6.5.svn:
bin <= empty
docs
etc
man
modules.xml
r.basin.bat <=
r.basin.py <=
r.ipso.bat
r.ipso.py
r.stream.angle.exe
r.stream.basins.exe
r.stream.del.exe
r.stream.order.exe
r.stream.pos.exe
r.stream.preview.bat
r.stream.preview.py
r.stream.stats.exe
r.wf.bat
r.wf.py
scripts
in the wxgui-commandline r.basin can be choosen, but
   File "C:\OSGEO4~1\apps\grass\grass-6.5.svn\etc\wxpython\gu
i_core\prompt.py", line 839, in OnItemSelected
self.cmdDesc = gtask.parse_interface(GetRealCmd(cmd))
   File "C:\OSGEO4~1\apps\grass\grass-6.5.svn\etc\python\gras
s\script\task.py", line 470, in parse_interface
tree = etree.fromstring(get_interface_description(name))
s\script\task.py", line 448, in get_interface_description
"\n\nDetails: %(det)s") % { 'cmd' : cmd, 'det' :
decode(cmderr) }
grass.script.core
ScriptError
Unable to fetch interface description for command
'r.basin.bat'.
Details: C:\OSGEO4~1\bin\python.exe: can't open file
'C:/OSGEO4~1/apps/grass/grass-6.5.svn/r.basin.py': [Errno 2]
No such file or directory
content of r.basin.bat:
@"%GRASS_PYTHON%" "%GISBASE%/r.basin.py" %*
addon-path isn't within the related bat-file, it searches in %GISBASE%
with following changes
r.basin.bat
@"%GRASS_PYTHON%" "%GRASS_ADDON_PATH%/r.basin.py" %*
r.basin-gui can be invoked, but running the script by 'run' in the r
.basin-wxgui raises following error
r.basin.py --verbose map=elevation@PERMANENT prefix=oh
easting=636654.791181 northing=218824.126649 threshold=20
C:\OSGEO4~1\bin\python.exe: can't open file 'r.basin.py':
[Errno 2] No such file or directory
(Sun Nov 24 15:47:59 2013) Befehl ausgeführt (0 Sek)
but starting within the wxgui-commandline
r.basin --verbose map=elevation@PERMANENT prefix=oh easting=636654.791181
ABSCHNITT 1a (von 4): Initiiere den Speicher.
ABSCHNITT 1b (of 4): Ermittle den Fluß aus der Karte heraus.
ABSCHNITT 2: A * Suche.
the script (which invokes two other python scripts) finishes now.
the '''winGRASS6.5.svn-approach/status''' regarding python addon-scripts
is '''much better''' than winGRASS6.4.svn-approach/status
what is missing for downgrading ticket?
- change in the bat-file for the python script '''%GISBASE%'''/xyz.py to
'''%GRASS_ADDON_PATH%'''/xyz.py
- run the script by the run-button in the script-wxgui should work
Ticket URL: <http://trac.osgeo.org/grass/ticket/2138&gt;
      Cpu: x86-64 |
Comment(by hellik):
in comparison additional information related to shell scripts
System Info
GDAL/OGR: 1.10.1
Python: 2.7.4
wxPython: 2.8.12.1
i.e. http://trac.osgeo.org/grass/browser/grass-
addons/grass6/vector/v.out.ascii.mat
the content of v.out.ascii.mat.bat
@"%GRASS_SH%" "%GRASS_ADDON_PATH%/v.out.ascii.mat" %*
see '''"%GISBASE%/r.basin.py"''' vs.
'''"%GRASS_ADDON_PATH%/v.out.ascii.mat"'''
it seems for addon shell scripts the path is correct.
I'm a little bit lost in g.extension.py to change the path to addons
correctly also for addon python script ...
Ticket URL: <http://trac.osgeo.org/grass/ticket/2138#comment:1&gt;
Component: Addons | Version: svn-releasebranch64
      Cpu: x86-64 |
Changes (by hamish):
  * version: unspecified => svn-releasebranch64
Comment:
see also #1768 and commit log message for r58199.
fwiw r.threshold.py from 6.5 addons was what I've been using for a test
case.
r58199 is the change 2 weeks ago to g.extension.py in devbr6 which makes
things a bit better by manually editing the wrapper .bat file to run
%GRASS_PYTHON% instead of sh.exe. It's just a hack though, and trades
python scripts working from the bash command line for them working in the
wxGUI command line (on Wingrass). For Wingrass I suspect the wxGUI might
be the more important one for the majority of users, but it makes me sad
to choose between them, better we should make it work from everywhere.
Since it (in part) trades one half-solution for another & I'm not happy
with the foundation it lays, I didn't backport it yet. But I guess a
partially working hack is better than known breakage, so it could be
backported.
with r58199 %GISBASE% -> %GRASS_ADDON_PATH% happens just before the SH ->
PYTHON on line 637.
> addons correctly also for addon python script ...
do you need a change beyond what is in 6.5's g.extension.py?
i.e. that a backport wouldn't solve?
AFAIK the .py extension association on Windows is the main problem,
getting that to work so you don't need to add the .bat extension to run
the module, and for the second pass it knows that $0 has an assumed .py
extension not an explicit one.
What we really need is an include/Make/PythonScript.make, I didn't get
very far with it beyond a minor edit to Script.make:
--- Script.make 2013-06-25 14:46:53.452338241 +1200
+++ PythonScript.make 2013-06-25 14:19:50.224336291 +1200
@@ -19,7 +19,7 @@
  $(SCRIPT): $(PGM)
         if [ ! -d $(SCRIPTDIR) ]; then $(MKDIR) $(SCRIPTDIR); fi
- $(INSTALL) $(PGM) $(SCRIPT)
+ $(INSTALL) $(PGM).py $(SCRIPT)
         $(MAKE) htmlscript scriptstrings
         $(MAKE) mancmd
It won't solve the association problem, but it will reduce the current
pile of hacks into a single clean place.
To be honest, my main concern isn't reall the downloadable Python addons
on WinGrass, since we can do a lot to fix that post-release as part of the
nightly builds, I'm much more concerned about custom user-composed Python
addon modules on Wingrass - that support has to be working out of the box
- it's a really important thing to have personal Python scripts working
for Windows users!
regards,
Hamish
(still ~90% AFK these weeks)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2138#comment:2&gt;
      Cpu: x86-64 |
Comment(by hamish):
Replying to [comment:2 hamish]:
> It's just a hack though, and trades python scripts working from
> the bash command line for them working in the wxGUI command
> line (on Wingrass).
by that I mean the overall commit, not the change from SH -> PYTHON.
The working one place but not the other trouble has to do with adding .py
in the wrapper .bat file & Window's extension associations IIRC.
H
Ticket URL: <https://trac.osgeo.org/grass/ticket/2138#comment:3&gt;
      Cpu: x86-64 |
Comment(by hellik):
tested with
System Info
GRASS SVN Revision: 58316
GDAL/OGR: 1.10.1
Python: 2.7.4
wxPython: 2.8.12.1
-> PYTHON on line 637.
I see it, but addons installed with ''Fetch & install extensions from
grass addons''
r.threshold.bat
@"%GRASS_PYTHON%" "%GISBASE%/r.threshold.py" %*
r.basin.bat
Ticket URL: <https://trac.osgeo.org/grass/ticket/2138#comment:4&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:4 hellik]:
grass addons''
> r.threshold.bat
> r.basin.bat
the same bat-file-content when installed by
g.extension.py extension=r.threshold operation=add
g.extension.py extension=r.basin operation=add
Ticket URL: <https://trac.osgeo.org/grass/ticket/2138#comment:5&gt;
      Cpu: x86-64 |
Comment(by neteler):
Should r58199 be backported? Did anyone test winGRASS 6.5.svn?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2138#comment:6&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:6 neteler]:
IMHO yes.
yes, it's me :wink:
Ticket URL: <http://trac.osgeo.org/grass/ticket/2138#comment:7&gt;
      Cpu: x86-64 |
Replying to [comment:7 hellik]:
> IMHO yes.
OK, backported in r58680. So to be tested in (win)GRASS 6.4.svn.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2138#comment:8&gt;
      Cpu: x86-64 |
Replying to [comment:8 neteler]:
Does it now work in 6.4.svn?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2138#comment:9&gt;
      Cpu: x86-64 |
Comment(by hellik):
sorry for the late response, I'm travelling ....
Replying to [comment:9 neteler]:
just a quick test
System Info
GRASS SVN Revision: 59095
GDAL/OGR: 1.10.1
Python: 2.7.4
wxPython: 2.8.12.1
g.extension.py extension=r.basin svnurl=http://svn.osgeo.org/grass/grass-
addons/grass6
Downloading precompiled GRASS Addons <r.basin>...
Updating metadata file...
Installation of <r.basin> successfully finished
(Fri Feb 28 11:13:50 2014) Befehl ausgeführt (14 Sek)
r.basin.bat
see http://trac.osgeo.org/grass/ticket/2138?replyto=9#comment:4
there is still '''%GISBASE%''' instead of '''%GRASS_ADDON_PATH%''' in the
related bat-file, altough it should be replaced
see
[http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/gui/scripts/g.extension.py?rev=58680#L637
line 637 of g.extension.py]
line = line.replace("%GISBSASE%", options['prefix'])
any idea?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2138#comment:10&gt;
      Cpu: x86-64 |
Comment(by martinl):
Replying to [comment:1 hellik]:
it was just a typo, should be fixed in r59750
Ticket URL: <http://trac.osgeo.org/grass/ticket/2138#comment:11&gt;
Reporter: hellik | Owner: martinl
     Type: defect | Status: assigned
      Cpu: x86-64 |
Changes (by martinl):
* cc: grass-dev@… (added)
  * owner: grass-dev@… => martinl
  * status: new => assigned
Ticket URL: <http://trac.osgeo.org/grass/ticket/2138#comment:12&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:11 martinl]:
right, the typo should be obvious :wink:
tested here with
System Info
GRASS SVN Revision: 59750
GDAL/OGR: 1.10.1
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
g.extension.py extension=r.flip svnurl=http://svn.osgeo.org/grass/grass-
addons/grass6
Downloading precompiled GRASS Addons <r.flip>...
Installation of <r.flip> successfully finished
the content of the related bat-file:
@"%GRASS_SH%" "%GRASS_ADDON_PATH%/r.flip" %*
and a python addon:
addons/grass6
@"%GRASS_PYTHON%" "C:\Users\xxx\AppData\Roaming\GRASS6\addons/r.basin.py"
the path for the python addon seems to be hard coded compared to a shell
addon?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2138#comment:13&gt;
      Cpu: x86-64 |
Replying to [comment:13 hellik]:
> @"%GRASS_PYTHON%"
"C:\Users\xxx\AppData\Roaming\GRASS6\addons/r.basin.py" %*
addon?
`GRASS_ADDON_PATH` could contain more directory paths. From this POV the
hardcoded path is probably better. It also relates for `prefix` option of
`g.extension`.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2138#comment:14&gt;
Priority: critical | Milestone: 6.4.4
      Cpu: x86-64 |
Changes (by hellik):
  * priority: blocker => critical
Comment:
Replying to [comment:14 martinl]:
> > @"%GRASS_PYTHON%"
shell addon?
`g.extension`.
it's just interesting why the same string exchange mechanism in
g.extension.py does different things for shell and python addon scripts
regarding path.
anyway downgrading priority; one step further to GRASS6.4.4 RC1.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2138#comment:15&gt;
      Cpu: x86-64 |
Replying to [comment:15 hellik]:
regarding path.
you are right, it's inconsistency, GRASS_ADDONS_PATH for bash scripts
probably comes from build system (GRASS 6 supports only Bash scripts). I
have changed `g.extension.py` in r59764 and r59765 to behave similarly
also for Python scrips.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2138#comment:16&gt;
      Cpu: x86-64 |
+1
Ticket URL: <http://trac.osgeo.org/grass/ticket/2138#comment:17&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:16 martinl]:
regarding path.
for the record I've closed #1768 as duplication of #1768. will close this
ticket after testing the upcoming nightly.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2138#comment:18&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:18 hellik]:
should be: for the record I've closed #1768 as duplication of this ticket.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2138#comment:19&gt;
