[GRASS-dev] [GRASS GIS] #2139: g.parser does not allow newline character in option value for Python scripts
scripts
Reporter: wenzeslaus | Owner: grass-dev@…
     Type: defect | Status: new
Component: Parser | Version: svn-trunk
Keywords: g.parser, scripts, newline, line break | Platform: All
      Cpu: Unspecified |
`g.parser` mechanism does not allow newline character when newline is in
option value. This applies to Python modules:
m.proj input=test.txt proj_out="+proj=lcc..."
proj_in="+proj=merc...+to_meter=1
C modules are fine:
g.proj proj4="
(error is ''Can't parse PROJ.4-style parameter string'' which means that
parser allowed module to continue)
When newline is in parameter, `g.parser -s module/name/or/path` will
output (for the above example):
@ARGS_PARSED@
flag_i=0
flag_o=0
flag_d=0
flag_e=0
flag_c=0
opt_input=-
opt_output=
opt_separator= ,
opt_proj_in=+proj=merc...+to_meter=1
opt_proj_out=+proj=lcc...+to_meter=1
I'm not sure how newlines should be handled, I haven't found a
documentation of this format.
Anyway, the problem is in
[source:grass/trunk/lib/python/script/core.py#L594 _parse_opts()] function
which stops when line is empty:
if not line:
     break
If the option with newline is not the last one, Python script will get the
`options` dictionary incomplete which causes unexpected error.
In my case I was running `m.proj` in a Python script with the parameter
`proj_in` obtained by `g.proj`:
proj_in = gcore.read_command('g.proj', flags='jf')
proc = gcore.start_command('m.proj', input='-', separator=' , ',
                            proj_in=from_proj, proj_out=to_proj,
                            stdin=gcore.PIPE,
                            stdout=gcore.PIPE, stderr=gcore.PIPE)
And the error I obtained was:
   File "/home/vasek/dev/grass/trunk_clang/dist.i686-pc-linux-
gnu/scripts/m.proj", line 292, in <module>
     main()
gnu/scripts/m.proj", line 121, in main
     proj_out = options['proj_out']
KeyError: 'proj_out'
Simple `proj_in.strip()` solves the problem in my case because the output
of `g.proj` is ended with a newline.
However, this is a general problem and if `g.parser` Python mechanism is
not able to handle newlines `g.parser` itself should give an error message
when user tries to input some newline. If `g.parser` Python mechanism
should allow newlines (anywhere in the option value) for all modules, the
output and/or the reader (`_parse_opts()` function) should be fixed
accordingly.
Maybe the `_parse_opts()` function should check the lines by regular
expressions `opt_.*=` and lines which does not match should be merged with
above option value (I'm not sure about last line, it might be empty
always, if so, it should not be merged).
Are there other suggestions, e.g. for some fast (in any sense)
implementation?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2139&gt;
scripts
      Cpu: Unspecified |
Comment(by glynn):
Replying to [ticket:2139 wenzeslaus]:
implementation?
r58339 adds a -n switch to g.parser to separate options with a null
character rather an newline, and modifies grass.script.parser() to use
that option.
This needs to be tested on Windows.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2139#comment:1&gt;
scripts
      Type: defect | Status: closed
Resolution: fixed | Keywords: g.parser, scripts, newline, line break
  Platform: All | Cpu: Unspecified
Changes (by wenzeslaus):
  * status: new => closed
  * resolution: => fixed
Comment:
I just tried one MS Windows computer with test command above and it worked
(command fails in wrong way, see #2140, but the parameters are passed).
Thanks for the fix. Closing the ticket, reopen when it will be failing on
other MS Windows machines.
To test this in correct way generate test file:
echo "100 200" > test.txt
Run test:
m.proj input=test.txt proj_out="+proj=lcc +lat_1=36.16666666666666
+lat_2=34.33333333333334 +lat_0=33.75 +lon_0=-79 +x_0=609601.22 +y_0=0
+no_defs +a=6378137 +rf=298.257222101 +towgs84=0.000,0.000,0.000
+to_meter=1" proj_in="+proj=merc +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0
+k=1.0 +no_defs +a=6378137 +rf=298.257223563 +towgs84=0.000,0.000,0.000
+to_meter=1
Check output:
10024493.03|-20933.49|0.00
Ticket URL: <https://trac.osgeo.org/grass/ticket/2139#comment:2&gt;
