#2140: m.proj does not handle cs2cs failure
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Component: Projections/Datums | Version: svn-trunk
Keywords: m.proj, cs2cs | Platform: All
Cpu: All |
When I input wrong proj strings to `m.proj` it calls `cs2cs` which fails
and `m.proj` does not handle its error correctly.
To test (you need to have `test.txt` with any content):
m.proj input=test.txt proj_out="bla bla bla" proj_in="another bla bla bla"
The error message is:
Rel. 4.8.0, 6 March 2012
<cs2cs>:
projection initialization failure
cause: unknown projection id
program abnormally terminated
File "/home/vasek/dev/grass/trunk_clang/dist.i686-pc-linux-
gnu/scripts/m.proj", line 292, in <module>
main()
gnu/scripts/m.proj", line 271, in main
x, y = xy.split('\t')
ValueError: need more than 1 value to unpack
I haven't investigated that but checking return code is probably enough.
''What is the correct Trac component for this ticket?''
Ticket URL: <https://trac.osgeo.org/grass/ticket/2140>
