#2147: db.databases not working in GRASS 7
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Component: Database | Version: svn-trunk
Keywords: db.databases | Platform: Unspecified
Cpu: OSX/Intel |
I just discovered that db.databases is not working in GRASS 7. Other db.*
modules seem to work OK.
db.databases location=nc_spm_08 driver=sqlite
dbmi: db_list_databases() not implemented
ERROR: Unable to list databases
Not sure which exact version I have, but I built it 12 December 2013. I
don't know what version because g.version is not returning the version
number.
Keywords: db.databases, sqlite | Platform: Unspecified
Cpu: OSX/Intel |
Comment(by cmbarton):
Replying to [comment:1 martinl]:
> This is strange. Function which list databases has been implemented for
SQLite driver 14 months ago (r53597). Do you have SQLite DB driver
compiled?
> db.driver -p
Yes. SQLite works fine and shows up in the driver list
GRASS 7.0.svn (nc_spm_08):~ > db.connect -d
D1/1: Creating new default DB params with db_set_default_connection()
Default driver / database set to:
driver: sqlite
database: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
This is OK. DBF driver has no implemented function to list databases.
> driver: sqlite
> GRASS 7.0.svn (nc_spm_08):~ > db.connect -p
> driver: sqlite
> database: /home/neteler/grassdata/nc_spm_08/user1/sqlite/sqlite.db
> schema:
> group:
> GRASS 7.0.svn (nc_spm_08):~ > db.databases
> D1/1: db_d_init_error(): SQLite
> D1/1: db count = 0
> No databases found
The command
db.connect -d
driver: sqlite
doesn't create database, so `db.databases` doesn't list any database. You
need to run command which writes attribute data to the database.
Keywords: db.databases, sqlite | Platform: All
Cpu: OSX/Intel |
Comment(by neteler):
Replying to [comment:5 martinl]:
> Replying to [comment:4 neteler]:
> > D1/1: db count = 0
> > No databases found
> The command
> db.connect -d
> driver: sqlite
> database. You need to run command which writes attribute data
> to the database.
Good point.
Maybe "db.connect -d" should create the (empty) sqlite.db file to
avoid user confusion.
Cpu: OSX/Intel |
Comment(by martinl):
Replying to [comment:6 neteler]:
Probably, in any case it should be discussed in the separate ticket. In
this case `db.connect` should behave similarly for all supported drivers,
ie. to create directory for DBF driver, new empty database for SQLite or
PostgreSQL drivers...
Cpu: OSX/Intel |
Replying to [comment:3 cmbarton]:
It's strange, as I already mentioned, function to list databases has been
implemented for SQLite driver 14 months ago. Please could you check
source:grass/trunk/db/drivers/sqlite/listdb.c in your local source code
tree.
Cpu: OSX/Intel |
Replying to [comment:8 martinl]:
been implemented for SQLite driver 14 months ago. Please could you check
tree.
Cpu: OSX/Intel |
Comment(by wenzeslaus):
Is something mentioned here still an issue?
If unclear state of source code is the remaining issue (as suggested by
last comments), please, check the file again. The best think to do is
probably
cd db/drivers/sqlite
svn status
However, `svn revert db/drivers/sqlite/listdb.c` and `svn up` and also
`svn diff` and `svn info` can be useful too.
Cpu: OSX/Intel |
I just checked and the behavior is the same as I originally reported. I've
run this from a mapset in my nc_spm_08 location that has a functioning
SQLITE database. That is, this mapset has vectors connected to an SQLITE
database that is working correctly. Yet I still get:
db.databases location=nc_spm_08nc_spm_08
ERROR: Unable to list databases. Try to define correct connection settings
by db.login.
The manual defines "location" as follows:
"Default location for SQLite driver is the full path for the current
mapset. For PostgreSQL driver it's empty connection string. "
This is NOT standard usage of the word "location" in GRASS. Nonetheless,
it doesn't seem to work when I put in the proper pathname either.
db.databases location=$GISDBASE/$LOCATION_NAME/$MAPSET
by db.login.
Same thing happens if I specify the path to the SQLite database itself:
db.databases location=$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
by db.login.
Maybe the command is no longer relevant. If it doesn't work, maybe it
should be dropped from the distribution.
