#2148: wxGUI modeler: allow to name elements in the model schema
Reporter: mlennert | Owner: grass-dev@…
Component: wxGUI | Version: svn-trunk
Keywords: modeller comments | Platform: Unspecified
Cpu: Unspecified |
It would be nice if by changing the name of an object in the Objects tab,
this name would replace the name of the command in the model display.
Currently setting this name just is ignored and is lost after saving and
reopening the model.
In addition, the possibility to add comments would be nice, possibly in
the form of a comment object that would be ignored in the model.
Cpu: Unspecified |
Comment(by martinl):
Replying to [ticket:2148 mlennert]:
tab, this name would replace the name of the command in the model display.
it was hopefully fixed in r58518, you can set action name/label in 'Items'
tab or from contextual menu ('Set label').
This has been implemented in r58521. You can set comments from contextual
menu, it's saved to model file. I am not sure how to display them,
probably as tooltips or directly in the object shape below label. Any
opinions?
Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:1 martinl]:
'Items' tab or from contextual menu ('Set label').
Works now, thanks !
in the form of a comment object that would be ignored in the model.
contextual menu, it's saved to model file. I am not sure how to display
them, probably as tooltips or directly in the object shape below label.
Any opinions?
I think the ideal would be to be able to add comments independent of
objects. Sometimes comments can be about a process that includes several
objects. And for such comments it would be nice to have a specific form
not yet used by other types of obects (triangle, hexagon, ...).
And to push things even further: it would be nice if these comments then
also show up in the Python code...
Cpu: Unspecified |
Replying to [comment:2 mlennert]:
> Works now, thanks !
I have also modified dialog for adding new commands to the model which now
enables setting label and comment, see attachment:modeler-label-
Any opinions?
This make sense.
Cpu: Unspecified |
Replying to [comment:3 martinl]:
Cpu: Unspecified |
Any opinions?
Comments related to the commands are now shown as !DividedShape, see
