GDAL
1
#2168: Memory error in G_matrix_inverse
Reporter: stopkovae | Owner: grass-dev@…
Type: defect | Status: new
Component: Default | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: x86-64 |
I would like to ask for error correction in ''G_matrix_inverse()''
function. It makes "''free(): invalid next size (fast)''" error.
I suggest replacing of
''perm = (integer *) G_malloc(wmat->rows);''[[BR]]
with[[BR]]
''perm = (integer *) G_malloc(wmat->rows * sizeof(int));''
in ''grass/trunk/lib/gmath/la.c'' (line 486).
Thank you in advance.
Eva
Ticket URL: <https://trac.osgeo.org/grass/ticket/2168>
GDAL
2
Cpu: x86-64 |
Comment(by huhabla):
Hi Eva,
thank yout for the bug report. It should be fixed in r58748. Please test
the changes.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2168#comment:1>
GDAL
3
Cpu: x86-64 |
Comment(by StopkovaE):
Hi Soeren,
thank you for fixing, it works fine.
Eva
Ticket URL: <http://trac.osgeo.org/grass/ticket/2168#comment:2>
GDAL
4
Type: defect | Status: closed
Resolution: fixed | Keywords:
Platform: Linux | Cpu: x86-64
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/2168#comment:3>
