#2174: Tcl NVIZ: load state loads then forgets the "look here" focus position
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Tcl/Tk NVIZ | Version: svn-develbranch6
Keywords: load state, focus | Platform: Linux
Cpu: x86-64 |
In Tcl/Tk NVIZ if you change the map's location on the canvas with the
"Look Here" button or change from the puck to the "center" view-adjust
method, then 'File -> Save State', the resulting position is successfully
saved to the session-state file by Nget_focus(), and is loaded back in ok
as part of panel_main.tcl's Nviz_main_load()'s Nset_focus(). But then the
focus position gets clobbered (twice) by panel_surf.tcl and panel_vol.c
calling "look_center", which resets the view. On a less important note
those extra two look_center mean that the screen gets redrawn a couple
extra times too; minor performance hit.
Commenting out the two look_center() at the ends of the Nviz_surf_load()
and Nviz_vol_load() tcl functions lets it reload the correct original view
upon File -> Load State.
I hesitate to commit any change without some sort of check that the focus
has already been loaded/set, maybe those two look_center() are there for
the first layer to be loaded when starting from a blank canvas? Note that
AFAIK the canvas center focus is based on g.region not the bounds of the
newly loaded surface/volume, so the view should not have to be recentered
because a change of layer.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2174>
