GDAL
January 28, 2014, 8:30am
1
#2176: create .grass7 directory at startup
Reporter: lucadelu | Owner: grass-dev@…
Type: defect | Status: new
Component: Default | Version: svn-trunk
Keywords: | Platform: Unspecified
Cpu: Unspecified |
I everybody,
testing g.gui.rlisetup I discovered that the .grass7 directory is created
only at the end of the first session that the user launch grass7.
This is a problem for modules like g.gui.rlisetup because they write on
.grass7 directory.
I added a patch to solve this issue, if you don't see any
contraindications I can submit it
Ticket URL: <http://trac.osgeo.org/grass/ticket/2176> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
January 28, 2014, 9:44am
2
Cpu: Unspecified |
Comment(by martinl):
Right, the '.grass7' directory is written on exit when storing '.rc' file
source:grass/trunk/lib/init/grass.py#L1379. Every session using copy of
'rc' file saved in temp file source:grass/trunk/lib/init/grass.py#L264.
Your patch seems to be reasonable. wxGUI behaves similarly
source:grass/trunk/gui/wxpython/core/settings.py#L989
Ticket URL: <http://trac.osgeo.org/grass/ticket/2176#comment:1> ;
GDAL
February 20, 2014, 2:40pm
3
Type: defect | Status: closed
Resolution: fixed | Keywords:
Platform: Unspecified | Cpu: Unspecified
Changes (by lucadelu):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:1 martinl]:
Ok, fixed in r59106
Ticket URL: <http://trac.osgeo.org/grass/ticket/2176#comment:2> ;
