[GRASS-dev] [GRASS GIS] #2177: g.gui.animation fail to create gif
Reporter: lucadelu | Owner: grass-dev@…
     Type: defect | Status: new
Component: wxGUI | Version: svn-trunk
Keywords: g.gui.animation | Platform: Unspecified
      Cpu: Unspecified |
Hi dev,
today I discovered that g.gui.animation fail to create gif image.
Until few weeks ago it worked really well, the error that we (my colleague
told me this problem and I'm able to replicate it) discovered is the
following
must be string or buffer, not None
Reason: must be string or buffer, not None
   File "/home/lucadelu/compilati/grass7/dist.x86_64-unknown-linux-
gnu/etc/gui/wxpython/animation/controller.py", line 554, in _export
     duration=self.timeTick / float(1000), repeat=True)
gnu/etc/python/grass/imaging/images2gif.py", line 575, in writeGif
     gifWriter.writeGifToFile(fp, images, duration, loops, xy, dispose)
gnu/etc/python/grass/imaging/images2gif.py", line 436, in writeGifToFile
     fp.write(globalPalette)
TypeError: must be string or buffer, not None
Ticket URL: <http://trac.osgeo.org/grass/ticket/2177&gt;
      Cpu: Unspecified |
Comment(by annakrat):
I cannot reproduce it. What version of PIL do you have? I assume 1.1.7?
Does this happen always or only in some cases? Luca, could you test what
you get here?
http://trac.osgeo.org/grass/browser/grass/trunk/lib/python/imaging/images2gif.py#L413
Maybe the getheader function returns None?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2177#comment:1&gt;
      Cpu: Unspecified |
Comment(by lucadelu):
Replying to [comment:1 annakrat]:
you get here?
Yes, it return a list of None values
Something else to test?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2177#comment:2&gt;
      Cpu: Unspecified |
It looks like some bug in Pillow. If you uninstall it and use PIL instead,
it should work. I am not sure if someone opened a ticket for this for
Pillow, I couldn't find anything.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2177#comment:3&gt;
      Cpu: Unspecified |
Replying to [comment:3 annakrat]:
instead, it should work. I am not sure if someone opened a ticket for this
for Pillow, I couldn't find anything.
Are you speaking about python-pillow?
Because it is not installed on my computer...
Ticket URL: <http://trac.osgeo.org/grass/ticket/2177#comment:4&gt;
      Cpu: Unspecified |
Replying to [comment:4 lucadelu]:
I was able to reproduce the error only when I installed Pillow. When I
uninstalled it, everything was fine. Also when you google the error
message, there has been a lot of people having the same problems recently
but I could not find any solution. Anyway, GRASS is not really responsible
for this error and I am not sure how can I fix it.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2177#comment:5&gt;
Hi Anna,
so some feedback here:
I tried in my brain scan location (that's a limited dataset):
GRASS 7.0.svn (markus_brain_ct):~ > g.gui.animation
GRASS_INFO_MESSAGE(19932,1): ERROR: Unsupported temporal database.
Version mismatch.
GRASS_INFO_MESSAGE(19932,1): Supported temporal database version is: 2
GRASS_INFO_MESSAGE(19932,1): Please remove your old temporal database.
GRASS_INFO_MESSAGE(19932,1): A new one will be created automatically.
GRASS_INFO_MESSAGE(19932,1): Current temporal database info:
GRASS_INFO_MESSAGE(19932,1): DBMI interface:..... sqlite3
GRASS_INFO_MESSAGE(19932,1): Temporal database:..
/home/neteler/grassdata/markus_brain_ct/PERMANENT/tgis/sqlite.db
GRASS_INFO_END(19932,1)
  File "/home/neteler/software/grass70/dist.x86_64-unknown-linux-gnu/scripts/g.gui.animation",
line 139, in <module>
    GuiModuleMain(main)
  File "/home/neteler/software/grass70/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/core/utils.py",
line 1070, in GuiModuleMain
    mainfn()
line 129, in main
    frame = AnimationFrame(parent=None, giface=StandaloneGrassInterface())
  File "/home/neteler/software/grass70/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/animation/frame.py",
line 63, in __init__
    tgis.init()
  File "/home/neteler/software/grass70/dist.x86_64-unknown-linux-gnu/etc/python/grass/temporal/core.py",
line 588, in init
    "info":get_database_info_string()}))
  File "/home/neteler/software/grass70/dist.x86_64-unknown-linux-gnu/etc/python/grass/pygrass/messages/__init__.py",
line 262, in fatal
    raise FatalError(message)
grass.pygrass.messages.FatalError: Unsupported temporal database.
Version mismatch.
I am not scared at all but I feel that it should suggest how to remove
it, in the phrase
"Please remove your old temporal database."
A silly user would do:
g.list db
--> db does not exist
GRASS 7.0.svn (markus_brain_ct):~ > db.tables -p
No tables found
so it is not that obvious how to "reach" the file. I have now simply removed it.
Perhaps also trap the "Version mismatch" with try/except or so?
More I'll add to the ticket.
      Cpu: Unspecified |
Comment(by neteler):
I tried on Fedora 20/64bit using the Pillow fix r:
It starts the GIF export, a file of 13 bytes is generated:
scan2013.gif: GIF image data, version 89a, 800 x 497
but it crashes with
The same error as originally reported.
AFAIK Luca uses PIL on Ubuntu while I use python-pillow 2.2.1 on Fedora.
Since PIL is no longer developed, Fedora switched to Pillow.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2177#comment:6&gt;
      Cpu: Unspecified |
Replying to [comment:6 neteler]:
Sorry, this one: r58940
Ticket URL: <http://trac.osgeo.org/grass/ticket/2177#comment:7&gt;
On Fri, Feb 7, 2014 at 4:31 PM, Markus Neteler <neteler@osgeo.org> wrote:
Hi Anna,
Version mismatch.
  File
    GuiModuleMain(main)
  File
    mainfn()
  File
line 129, in main
  File
    tgis.init()
  File
line 588, in init
  File
line 262, in fatal
Version mismatch.
it, in the phrase
g.list db
No tables found
removed it.
Not sure if try/except and then GUI window is needed. More important is the
content of the message. Not only that it does gives suggestion what to do
but it is misleading since it is silent about the fact that simple removal
(which is suggested) will lead to the data loss.
In #2158, I say:
Sentences `Please remove your old temporal database. A new one will be
created automatically.` could seem that you just remove the old file and
the new one will be created. It isn't that simple, you will loose your
temporal data. This detail should be mentioned in the message.
Shouldn't the message say something like `Please backup and then remove
your old temporal database.`? Maybe with some suggestion how to backup. Or
do you have some other idea, how to deal with this?
http://trac.osgeo.org/grass/ticket/2158#comment:7
Vaclav
grass-dev mailing list
grass-dev@lists.osgeo.org
      Cpu: Unspecified |
Luca, are you sure you don't have Pillow on your computer? I have the same
problem only when I install Pillow. When I uninstall it, it's working
again. So it looks like it is a Pillow problem.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2177#comment:8&gt;
      Cpu: Unspecified |
Replying to [comment:8 annakrat]:
same problem only when I install Pillow. When I uninstall it, it's working
Sorry Anna, I discovered that python-PIL install python-pillow. So I'm
using Pillow, Debian Jessy not provide PIL, we should try to fix this
problem or report this bug in Pillow.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2177#comment:9&gt;
      Cpu: Unspecified |
I still get this error with current relbr7 (r61295 on Fedora
3.14.8-200.fc20.x86_64 with python-pillow-2.2.1-4.fc20.x86_64).
However, I found a partial solution here (patch attached):
http://stackoverflow.com/questions/19149643/error-in-images2gif-py-with-
globalpalette
Disadvantage: the background is then black and no more white but at least
it stops crashing.
Something more here:
http://stackoverflow.com/questions/18325419/error-when-creating-gif-using-
images2gif-py
and an apparently slightly updated version here (which contains this bug
but other fixes):
https://code.google.com/p/visvis/source/browse/vvmovie/images2gif.py
Ticket URL: <http://trac.osgeo.org/grass/ticket/2177#comment:10&gt;
      Cpu: Unspecified |
Thanks to this
https://github.com/rec/echomesh/blob/master/code/python/external/images2gif.py,
I hopefully fixed it in r61417 in trunk. It should work with PIL or Pillow
or both installed. Please test.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2177#comment:11&gt;
      Cpu: Unspecified |
Excellent, the animated GIF export works now in trunk, thanks.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2177#comment:12&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: g.gui.animation
  Platform: Unspecified | Cpu: Unspecified
Changes (by annakrat):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:12 neteler]:
Tested on Windows and backported in r61427.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2177#comment:13&gt;
