#2178: No polygon fill when using the pnv display driver
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Component: Display | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
When using png display driver, only polygon boundaries are shown, i.e.,
they are shown without fill. Using the cairo display driver, things work
as expected.
Keywords: pngdriver | Platform: Unspecified
Cpu: Unspecified |
Comment(by pvanbosgeo):
I am running on Linux (Ubuntu 13.10). I just tried the North Carolina
sample dataset, but that works fine.
Layers from one of my mapsets copied to the North Carolina dataset (using
v.proj) display fine.
The other way around, layers from the North Carolina dataset copied to my
location/mapset (again, using v.proj) do not display correctly (missing
fill). See the attached GRASS dataset (GRASStest) with in the location
latlon, mapset PERMANENT one layer nc_state copied from the North Carolina
dataset.
