[GRASS-dev] [GRASS GIS] #2184: MySQL Error during 'v.in.ogr' in GRASS 7 SVN (2014-01-31)
Reporter: justinzane | Owner: grass-dev@…
     Type: defect | Status: new
Component: Vector | Version: svn-trunk
Keywords: MySQL, OGR, import | Platform: Linux
      Cpu: x86-64 |
It seems that there is a failure to properly quote the CREATE TABLE
command. Simply adding backticks "`" around the table name and all column
names allows the command to execute.
This looks like {{{create table `natural` (`cat` integer, `osm_id` varchar
(11), `name` varchar (48), `type` varchar (16));}}}.
Additionally, even though the CREATE TABLE failed and therefore the import
failed, a map is created and cannot be removed since its backing data
table never existed.
So, two separate issues need to be fixed. First the quoting. Second is the
need to wait until the import has succeeded before allocating a 'Map'.
v.in.ogr dsn=/home/justin/downloads/osm_CA/natural.shp
DBMI-MySQL driver error:
Unable to execute:
create table natural (cat integer, osm_id varchar ( 11 ),
name varchar ( 48 ), type varchar ( 16 ))
You have an error in your SQL syntax; check the manual that
corresponds to your MySQL server version for the right
syntax to use near 'natural (cat integer, osm_id varchar (
11 ), name varchar ( 48 ), type varchar (' at line 1
ERROR: Unable to create table: 'create table natural (cat integer, osm_id
varchar ( 11 ), name varchar ( 48 ), type varchar ( 16 ))'
Ticket URL: <http://trac.osgeo.org/grass/ticket/2184&gt;
      Cpu: x86-64 |
Changes (by justinzane):
* cc: justinzane (added)
Comment:
Note that this may properly belong under "Database".
Also, in the off chance it is wanted, I can provide all configure/build
logs.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2184#comment:1&gt;
      Type: defect | Status: closed
Resolution: invalid | Keywords: MySQL, OGR, import
  Platform: Linux | Cpu: x86-64
Changes (by neteler):
  * status: new => closed
  * resolution: => invalid
Comment:
According to
  * http://dev.mysql.com/doc/refman/5.7/en/reserved-words.html
  * http://dev.mysql.com/doc/refman/5.7/en/identifiers.html
  * http://stackoverflow.com/questions/12658763/why-did-i-have-to-use-
backticks-around-the-table-name-in-my-mysql-query
backticks are required if the identifier is a reserved word, contains
white space, etc.
The word "NATURAL" is a reserved word in MySQL (see Table 9.2 in the first
link).
To solve this conflict for you, you can use the "cnames" parameter of
v.in.ogr to
change the column names during import. The GRASS DB drivers should not try
to
automatically launder names.
To give more help in the manual, I have added some remarks in r59058
(backported in
r59059 and r59060).
Closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2184#comment:2&gt;
