#2188: GRASS fails to start on Windows since r58807
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: pygrass, tgis | Platform: Unspecified
Cpu: Unspecified |
Adding temporal vector algebra (r58807) broke compilation on Windows and
some Ubuntu machines. During start up it fails:
Cleaning up temporary files...
Starting GRASS GIS...
File "C:\Program Files (x86)\GRASS GIS
7.0.svn\etc\gui\wxpython\gis_set.py", l
ine 48, in <module>
from gui_core.dialogs import TextEntryDialog
7.0.svn\etc\gui\wxpython\gui_core\dialo
gs.py", line 49, in <module>
from gui_core.gselect import LocationSelect, MapsetSelect, Select, \
7.0.svn\etc\gui\wxpython\gui_core\gsele
ct.py", line 59, in <module>
import grass.temporal as tgis
7.0.svn\etc\python\grass\temporal\__ini
t__.py", line 29, in <module>
from temporal_vector_algebra import *
7.0.svn\etc\python\grass\temporal\tempo
ral_vector_algebra.py", line 436, in <module>
m_overlay = pygrass.Module('v.overlay', quiet=True, run_=False)
7.0.svn\etc\python\grass\pygrass\module
s\interface\module.py", line 247, in __init__
raise GrassError(str_err % self.name)
grass.pygrass.errors.GrassError: "Module 'v.overlay' not found, please
check tha
t the module exist"
Error in GUI startup. If necessary, please report this error to the GRASS
develo
pers.
I will move the tgis import to the places where it's actually needed, so
it won't be imported when the gui starts. But still I am not sure about
the other imports in temporal_vector_algebra.py. Can tgis be used without
pygrass? Is pygrass needed for temporal vector algebra only? The imports
should be more careful. Also it would be good to understand what's the
problem with pygrass.Module v.overlay.
Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:2 zarch]:
> Hi Anna,
> Replying to [ticket:2188 annakrat]:
> > what's the problem with pygrass.Module v.overlay.
> [[BR]]
> The problem is that Module try to run:
> get_cmd_xml = subprocess.Popen([cmd, "--interface-description"],
> stdout=subprocess.PIPE)
> But an OSError is raised.
> I've modified the code to give a clearer message and avoid to mask the
original error, see (r58885).
GRASS starts again, however temporal framework is not working because the
original problem is still there. PyGRASS Module class is not working on
Windows (I created ticket #2189). Discussion in #2067 suggests that during
import, no PyGRASS Module should be created which is unfortunately
happening in
[http://trac.osgeo.org/grass/browser/grass/trunk/lib/python/temporal/temporal_vector_algebra.py#L436
temporal_vector_algebra.py].
Cpu: Unspecified |
Comment(by huhabla):
I committed a patch that should solve the import problem of the temporal
vector algebra, please try r58915.
I have removed the PyGRASS module creation at import time, which is bad by
design.
Replying to [comment:4 huhabla]:
by design.
Thanks a lot. We fixed also the #2189 in PyGRASS, so now everything should
be working.
