#2191: d.menu R_panel_restore() filling with garbage from the X buffer
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Display | Version: svn-develbranch6
Keywords: d.menu, D_popup() | Platform: Linux
Cpu: x86-64 |
there's a Xdriver rendering bug when calling d.menu, after it is complete
it should restore the monitor to how it was before the module started, but
there's something wrong in R_panel_restore() in
grass6/lib/display/popup.c. Instead of restoring the saved rectangle it
restores X-buffer junk.
i.ask and d.barscale use similar R_panel_*() calls and they work fine.
Coords in the panel's .tmp/ file looks ok AFAICT. It's pretty simple
function usage but I can't seem to see what's wrong.
example for r.li.setup:
d.mon x0
d.erase
d.menu bcolor=aqua tcolor=black << EOF
.T 20
.L 20
Next select area with mouse
[ Ok ]
EOF
bug is present in at least grass versions 6.4.2-6.5svn.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2191>
