#220: i.rectify should not let choose a raster not inside the selected group
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: All
Cpu: Other |
This would reduce the likelihood of errors like this:
Input file <yyy@PERMANENT> does not exist in group
<skan@PERMANENT>.
Try:
skan
xxx
ERROR: Exit!
Resolution: | Keywords:
Platform: All | Cpu: Other
Comment (by hamish):
Comment (by msieczka):
Replying to [comment:1 hamish]:
> command line example to recreate this, please?
> or is this from the wxGUI only, or...?
Resolution: | Keywords: i.rectify
Changes (by martinl):
Comment (by cmbarton):
I'm pretty sure that this is fixed, though I don't quite understand the
error here. Can you confirm?
Reporter: msieczka | Owner: grass-dev@…
Type: defect | Status: closed
Resolution: fixed | Keywords: i.rectify
Changes (by neteler):
