[GRASS-dev] [GRASS GIS] #2203: wxGUI module dialogs should provide "reset to default value" for each of parameters
parameters
Reporter: marisn | Owner: grass-dev@…
     Type: defect | Status: new
Component: wxGUI | Version: unspecified
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
Some of autogenerated module dialog input options contain their default
value. Current implementation has two downsides:
  * there is no way how to get back "default" value if it has been changed
(a wish for a new feature)
  * once value has been changed, it gets added to the command parameters
list (nice). The problem - if it's a number field (represented by a spiner
control), there is no way how to remove it from the module parameter list
(a bug)
Potential solution:
Autogenerate a button for each of input fields "reset to default". If
default value is not specified, it should just clear the input field. If
the default value is provided, it should just reset to default value. In
both of cases it should remove parameter from module parameter list.
Steps to reproduce:
run g.region, change cols or rows parameter, change your mind and try to
NOT provide cols or rows parameter. In current wxGUI form it is NOT
possible to NOT use cols or rows parameter as soon as you have touched
those input controls.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2203&gt;
parameters
      Cpu: Unspecified |
Changes (by annakrat):
  * type: defect => enhancement
Comment:
Replying to [ticket:2203 marisn]:
changed (a wish for a new feature)
(a bug)
> Potential solution:
In my opinion, the dialog would be too cluttered with all these buttons
and we can't use for example context menu because we want to keep the
system context menu. There could be one button to reset all fields but
this probably doesn't make any sense.
> Steps to reproduce:
There is already #1048, so let's keep discussion on this g.region problem
there.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2203#comment:1&gt;
