#2203: wxGUI module dialogs should provide "reset to default value" for each of
parameters
Reporter: marisn | Owner: grass-dev@…
Component: wxGUI | Version: unspecified
Resolution: | Keywords:
Comment (by mlennert):
Replying to [comment:1 annakrat]:
> Replying to [ticket:2203 marisn]:
> > Some of autogenerated module dialog input options contain their
default value. Current implementation has two downsides:
> > * there is no way how to get back "default" value if it has been
changed (a wish for a new feature)
> > * once value has been changed, it gets added to the command
parameters list (nice). The problem - if it's a number field (represented
by a spiner control), there is no way how to remove it from the module
parameter list (a bug)
> > Potential solution:
> > Autogenerate a button for each of input fields "reset to default". If
default value is not specified, it should just clear the input field. If
the default value is provided, it should just reset to default value. In
both of cases it should remove parameter from module parameter list.
> In my opinion, the dialog would be too cluttered with all these buttons
and we can't use for example context menu because we want to keep the
system context menu. There could be one button to reset all fields but
this probably doesn't make any sense.
I've very little knowledge of wx and am just brainstorming here, but I see
that spin.ctrl has an option 'initial='. Couldn't this be set to some
specific value (e.g. -1) and the parser interpret this value to mean that
this parameter should be ignored ?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2203#comment:2>
