[GRASS-dev] [GRASS GIS] #2205: Unicode unequal comparison in location wizard when title contains non-ascii letters
letters
Reporter: marisn | Owner: grass-dev@…
     Type: defect | Status: new
Component: wxGUI | Version: svn-trunk
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
In location wizard one just has to use "āšņļ" as the location title.
C:\Program Files\GRASS GIS
7.0.svn\etc\gui\wxpython\location_wizard\wizard.py:20
64: UnicodeWarning: Unicode unequal comparison failed to convert both
arguments
to Unicode - interpreting them as being unequal
   if current_gdb != database:
PERMANENT/MYNAME seems to be created correctly (UTF-8 without BOM).
Tested on Vista with r59159
Ticket URL: <http://trac.osgeo.org/grass/ticket/2205&gt;
letters
      Cpu: Unspecified |
Comment(by marisn):
Still happens with 7.0.0 r63925 on Vista.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2205#comment:1&gt;
letters
      Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:1 marisn]:
location title works for me in Vista, but not location name:
   File
"C:\OSGeo4W\apps\grass\grass-7.1.svn\gui\wxpython\gui_core\widgets.py", l
ine 759, in Validate
     if not self._condition(text):
   File
"C:\OSGeo4W\apps\grass\grass-7.1.svn\etc\python\grass\script\core.py", li
ne 1509, in legal_name
     's': s, 'il': illegal})
   File
ne 570, in warning
     message(msg, flag='w')
   File
ne 516, in message
     run_command("g.message", flags=flag, message=msg, errors='ignore')
   File
ne 373, in run_command
     ps = start_command(*args, **kwargs)
   File
ne 349, in start_command
     val = encode(val)
   File
"C:\OSGeo4W\apps\grass\grass-7.1.svn\etc\python\grass\script\utils.py", l
ine 218, in encode
     return string.encode(enc)
   File "C:\OSGeo4W\apps\Python27\lib\encodings\cp1252.py", line 12, in
encode
     return codecs.charmap_encode(input,errors,encoding_table)
UnicodeEncodeError: 'charmap' codec can't encode character u'\u0101' in
position
  18: character maps to <undefined>
Ticket URL: <http://trac.osgeo.org/grass/ticket/2205#comment:2&gt;
letters
      Cpu: Unspecified |
Comment(by annakrat):
Replying to [ticket:2205 marisn]:
arguments
It doesn't seem to do anything with the location title, the location name
is important. What is the name of the location you are creating and what
is the name of the location you were previously in (saved in rc file I
think)?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2205#comment:3&gt;
letters
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:2 hellik]:
encode
position
No surprise there. U+0101 ("LATIN SMALL LETTER A WITH MACRON") doesn't
exist in cp1252 (Western Europe); I believe that cp1257 (Baltic) is the
correct codepage for this.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2205#comment:4&gt;
letters
      Cpu: Unspecified |
Comment(by marisn):
Re-tested with 7.0.0 r64041 after removing the AppData/Roaming/GRASS
folder and it was still an issue. I couldn't perform any other tests, as
g.gui is failing on this build (different issue).
I managed to track it down - grass.gisenv() returns str, but database is
unicode. I took the liberty to fix it for 7.1 in r64044
No more warnings on my Vista box and Linux box.
I would say that this needs to be backported to releasebranch (unless it
needs to be reverted as a band aid and grass.gisenv() is changed to return
unicode strings). I'm leaving for the wx and Python gurus to decide.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2205#comment:5&gt;
