[GRASS-dev] [GRASS GIS] #2205: Unicode unequal comparison in location wizard when title contains non-ascii letters
letters
  Reporter: marisn | Owner: grass-dev@…
      Type: defect | Status: closed
  Priority: normal | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Resolution: fixed | Keywords:
Changes (by marisn):
* status: new => closed
* resolution: => fixed
* milestone: 7.0.3 => 7.1.0
Comment:
Replying to [comment:8 hellik]:
> so still an issue?
Your test is not an indicator of THIS problem. As per Glynn's comment,
"āšņļ" will be a valid test only for Windows set to run with Baltic
locale, you most likely run Western Europe version thus the test text
should be: "äêíõû"
As in one year nobody has cared to deal with encoding mess, closing this
as fixed in 7.1.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/2205#comment:9&gt;
