stream_order attribute table now contains a column 'flow_accum'. There is
no mention of this column in the man page. What exactly do the numbers in
that column represent ?
#2218: r.stream.order: lack of documentation for flow_accum column in attribute
table
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Component: Addons | Version: svn-releasebranch70
Resolution: | Keywords: r.stream.order, flow_accum
Changes (by madi):
* owner: Madi => grass-dev@…
Comment:
fwiw, I made some manual calculations in order to establish what the
column 'flow_accum' represents. My hypothesis was that it represented the
difference between the value of flow accum in the node downstream minus
the accum in the node upstream. But my hypothesis was not verified,
although the magnitude is comparable. If someone has better ideas I'm
ready to test. Thanks
