#2219: wish: all modules that create a new map should put the module call into
history
Reporter: mlennert | Owner: grass-dev@…
Component: Default | Version: svn-trunk
Keywords: history module call | Platform: Unspecified
Cpu: Unspecified |
Most raster modules do this already, but many vector modules don't, but I
think it would be very helpful if all newly created map could contain the
module call that created it in its history/support file.
Is this something that needs to be done module by module, or is there a
possibility to +/- automate this ?
history
Component: Vector | Version: svn-trunk
Keywords: history module call | Platform: All
Cpu: Unspecified |
Changes (by neteler):
* platform: Unspecified => All
* component: Default => Vector
Comment:
This is the unfiltered list of vector commands potentially lacking
Vect_hist_command():
history
Cpu: Unspecified |
Comment(by mlennert):
Actually, I notice that my understanding was wrong: command history is
often written, but it is not displayed when you use v.info (aka Metadata
in the wxGUI), you have to explicitly as for v.info -h.
This is not the case for most raster modules, where you see the command
history with r.info, without the need for the -h flag.
Any reason for that difference ?
I think that creation command history is important enough to be part of
the "base" package of information delivered by the r/v.info commands.
history
Cpu: Unspecified |
Replying to [comment:1 neteler]:
> Which is most important for you?
I would say all that create information for which it is important to
remember how it was created. So, in a quick scan of the list:
history
Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:3 mlennert]:
* vector/v.to.rast/main.c
* already there: Rast_command_history()
* vector/v.vect.stats/main.c
* not generating a map
* vector/v.lrs/v.lrs.label/main.c
* done in r59251
* vector/v.lrs/v.lrs.create/main.c
* done in r59252
* vector/v.lrs/v.lrs.segment/main.c
* done in r59253
* vector/v.net.visibility/main.c
* done in r59247; additionally r59248
* vector/v.kcv/main.c
TODO: Here is would be nice to "inject" the vector cmd history into the
raster history function (no idea how?) in order to write it out for the
raster output:
* vector/v.surf.idw/main.c
* vector/v.neighbors/main.c
* vector/v.to.rast3/main.c
history
Cpu: Unspecified |
Replying to [comment:4 neteler]:
No, but having the command history to see which command call was used to
fill the attribute column could be useful...
> * done in r59251
> * done in r59252
> * done in r59253
Thanks !
Agreed that it's not really useful here.
> raster output:
This should be the same as v.to.rast, no ?
How about the other way around: raster->vector modules ?
But again, my main issue is actually that to see that history you have to
use the -h flag for vectors, but not for rasters...
