#222: v.in gns broken in grass 7.0 trunk
Reporter: gisix | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.3.1
Component: Vector | Version: svn-trunk
Keywords: v.in.gns | Platform: Linux
Cpu: x86-32 |
v.in.gns aborts when applied to a country file:
GRASS 7.0.svn (wgs84_4326):~/gns > v.in.gns --overwrite file=ce.txt
vect=sri
Converted 36554 place names.
WARNUNG: Vector map <sri> already exists and will be overwritten
Scanning input for column types...
Current row:
'RC;UFI;UNI;LAT;LONG;DMS_LAT;DMS_LONG;MGRS;JOG;FC;DSG;PC;CC1;ADM1;ADM2;POP;ELEV;CC2;NT;LC;SHORT_FORM;GENERIC;SORT_NAME;FULL_NAME;FULL_NAME_ND;MODIFY_DATE'
FEHLER: Unparsable latitude value in column <3>: LAT
FEHLER: Unable to open vector map <sri@gns> on topology level 2
Resolution: | Keywords: v.in.gns
Platform: Linux | Cpu: x86-32
Old description:
vect=sri
Current row:
New description:
vect=sri
Current row:
vect=sri
Current row:
New description:
vect=sri
Current row:
Comment:
(milestone tag fixed)
I am not sure how to address this problem if the GNS format is a moving
target...
> vect=sri
> Current row:
New description:
vect=sri
Current row:
Comment:
target...
Is this the shell version or the Python version?
AFAICT, the Python version will never copy the first row to the
temporary file passed to v.in.ascii, regardless of its contents. Also,
the temporary file should always match the original hard-coded schema,
regardless of the schema used by the input data.
[The reason for this is that the test file which I used for testing
didn't match the original hard-coded schema.]
In retrospect, it would probably be better to import the data verbatim
(i.e. with the schema from the first row of the file), and simply
adjust v.in.ascii's x= and y= parameters to match the file.
