#2225: Improvements python shell
Reporter: jradinger | Owner: grass-dev@…
Component: Python | Version: unspecified
Keywords: | Platform: Linux
Cpu: x86-32 |
There are 3 small issues where the GUI python shell (tested in G7) can be
greatly improved:
1) Unlike other command shells it is possible to move the cursor to
positions even before the first position (indicated by the ">>>" symbol. I
don't know if this is a desired effect or is useful in any case?
2) When copy-pasting two python command into the shell, only one (the
first) one is processed. E.g.:
3) At the moment it is not possible to get past commands (command history
like in the Terminal) with the arrow up key. Using the arrow key causes
the cursor moving up (see issue 1)
Replying to [ticket:2225 jradinger]:
be greatly improved:
At least you cannot write there. I think it is a bug, I don't see any use
case.
> grass.read_command("g.version")
> grass.read_command("g.version", flags="e")
> GRASS 7.0.svn (2014)
True, this is strange behavior. Pasting
print "a"
print "bb"
prints just `a`. Note that second command is not really executed (tested
with a = 1 and a += 1). While pasting
for a in [1, 2, 3]:
print a
works as expected.
history like in the Terminal) with the arrow up key. Using the arrow key
causes the cursor moving up (see issue 1)
You can use Ctrl and arrows, this will move you thought history. The
question is if just arrow key wouldn't be better.
I'm afraid that most of these problems are in the underlying wxPython
PyShell.
